Thread: PG Multi port valve
    Mar 2014
    Essex
    2
    Smile PG Multi port valve
    Hello,
    I have just purchased a house with a pool, I have opened it up last weekend and I have noticed a leak on the multiport valve when I turn the pump off.
    Also experiencing a lot of air being pumped back into the pool.
    I suspect the valve is the cause of the problem, could anyone advise me on what gokit to purchase for my valve as I am unable to find the model online, please see the picture below.
    Thanks
    Andy
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: PG Multi port valve
    Welcome to TFP!
    The leak on the valve may be due to a bad O-ring. Is the water coming out around the handle? Can you take a picture showing more equipment? Maybe someone will recognize something to tell you who made it.
    Your air leak is another issue. Your multiport is on the pressure side of your system and can't leak air. Check out the Pool School article on air leaks for some help in figuring it out http://www.troublefreepool.com/conte...side-air-leaks
