Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Advice on where to start with pool stains
    Feb 2014
    Dallas, TX
    77
    Question Advice on where to start with pool stains
    I have some staining on my plaster and I'm trying to figure out the best way to deal with it. There are two types. The first is a light brown on the steps and a patch on the bottom. To me it looks like it’s just dirty and I thought a brush and vacuum would clean that up. However, when I tried brushing these areas pretty hard, it had no effect at all. The other stain appears to be rust under the light fixture. Again, I tried brushing and it had no effect.
    Remedies I have read include: rubbing the stains with vitamin C, rubbing stains with triclor pucks, SLAMing the pool and no drain acid wash.
    Is there a preferred methodology on when to apply these treatments? Is there something else I should try?
    Tom,
    22k IG plaster pool, Haywood DE6020 Pro Grid DE filer
    Century Centurion 2 HP single speed with Challenger Pentair front housing replacement. Polaris 280 and Polaris PB4-60 pump. Stenner Injection
    Pool is probably 1980-1990 vintage. Concrete deck
    38,305
    Re: Advice on where to start with pool stains
    First you need to ID the type of stain. Try the Vitamin C and the trichlor on each stain and see if they fade with one or the other.
    After that, then you can come up with a remedy plan.
    Feb 2014
    Dallas, TX
    77
    I had a feeling that was going to be the answer. I was hoping there was something I could do without having to get into 50 degree water.
    Tom,
    38,305
    Put the puck or vitamin C in a sock and tie it to your brush pole
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If this does work, you may want to do a Hydrogen Peroxide / Ascrobic Acid treatment while the water is still cold as one key to this is to remove all chlorine from the water before starting on the treatment. (a side benefit to using the Hydrogen Peroxide is it will also eliminate remaining chlorine as well as help lift the stain). I did this over the winter as I had some rust stains on my vinyl liner (from rust getting into the pool while the metal roof was replaced last year), within an hour of initial treatment stains were lighter, but most of them came up when my robot cleaner went over the area next, my guess is it also helped release the stain from the liner, but did not completely dissolve it.
    In my case I used about 1.5 gallons of 3% Hydrogen peroxide (bought out the local dollar store at $.39 per quart) and about 5 pounds of food grade ascorbic acid (from ebay).
    Ike
    Feb 2014
    Dallas, TX
    77
    Triclor pucks did not seem to do anything to either type of stain. Vit C was able to remove the light brown "dirt" looking stains. The darker orange rust looking stains are starting to show up in more places. I also saw the my CC is up to 1 so I started the SLAM process this morning. Been keeping my FC above 20 (CYA at 50). No impact on the stains so far.
    Tom,
    Feb 2014
    Dallas, TX
    77
    Any suggestions? I've been SLAMing for 2 days now with no effect. Here is what the spots look like.
    Tom,
    38,305
    If the trichlor tablet had no effect, then SLAM level FC levels will not either.
    Sounds like the vitamin C was helping some. With the few spots, you may want to get aggressive by hand with the Vitamin C.
    Feb 2014
    Dallas, TX
    77
    Vitamin C didn't help these dark orange ones.
    Tom,
    If you haven't already, try leaving a vitamin C tablet directly on one of the orange stains until it dissolves on it's own and see if that does anything.
    Tan and orange are both colors that tend to be iron stains, and vitamin C is expected to work on both of them. The orange stains likely contain more iron, and so would be expected to take more vitamin c and more time.
    Feb 2014
    Dallas, TX
    77
    Quote Originally Posted by JasonLion View Post
    Dissolving the tablet faded the stain slightly but did not remove it. Do I just keep putting more vitamin C on them? They are showing up all over the pool.
    Tom,
    Feb 2014
    Dallas, TX
    77
    One thing that may be causing it. The clip on my pool light fixture broke off so I fixed it with an old L bracket I had. It was just plain steal so it's probably rusting. Could that be causing these spots all over the pool?
    Tom,
    Yes it could be the cause, there might also be iron in your fill water.
    The first step is to ID the stains, which are sounding more and more like iron stains. The second step is to do an AA treatment to remove the stains, after which you are going to need to use sequestrant to keep them removed.
    Feb 2014
    Dallas, TX
    77
    After being gone 2 weeks I now have a week at home to work on this. I pulled the light and the rust was definitely coming from that. I've been reading up on AA treatments and found a thread about using HP with the AA method
    http://www.troublefreepool.com/threa...l=1#post606590
    Was wondering if I should go that route or just the traditional AA method. Any thoughts?
    Tom,
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I used a combination of H2O2 and AA on my treatment, although not nearly as much H2O2 as that message thread suggested, personally I see it as a bonus item, you want to make sure to start with no FC and H2O2 will quickly remove any FC and any excess of H2O2 will help the process before adding the AA. In my case it worked, but was slow and I did not add any FC back into the water until the next day, if I had to do it over I would probably use more H2O2.
    Ike
    Feb 2014
    Dallas, TX
    77
    Last night I did the HP with AA treatment exactly as described in the thread I posted above. Wow was that pricey. It cleaned up about 80-90% of the rust stain under the light. There are still some yellow/orange spots on the steps at the other side. Should I do another full AA treatment tonight or is there a way to spot treat the remaining area?
    Tom,
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If you have not added chlorine back yet give it a few more hours to work, it may finish it off, also try to scrub, when I did mine a few passes with the robot cleaner finished off the stain.
    Ike
    Feb 2014
    Dallas, TX
    77
    I already added back the chlorine an hour ago. The instructions made it sound like I'd get algae if I let it go past sun up. I actually sleep a little late, freaked out and ran down stairs to dump in the bleach. I will try brushing.
    Tom,
    Feb 2014
    Dallas, TX
    77
    Update: No noticeable change after brushing
    Tom,
  20. Back To Top    #20
    Feb 2014
    Dallas, TX
    77
    Having trouble getting the FC up. Per the instructions I calculated that I would need 1936 oz (~16 121 oz bottles) of 8.25 % bleach to raise the FC to 10. I've already added 20 bottles and had my Stenner pump going on max for the last 3 hours. (10 gal per day rate) I've only now just gotten the FC to register on the test and it's currently at 2 PPM. I just added 2 more 121 oz bottles of bleach which brings my total to 2662 oz of 8.25 % plus about 160 oz of 6% from the Stenner. That's almost 50% more then I was expecting. Does this sound right?
    Also my ph looks really low. It's yellow color that is lighter than even the lowest on the scale. (7.0) Should I try to adjust that up or just wait and get my FC right?
    Edit: After the last two 121 oz bottles FC now is at 7.5 PPM
    Tom,
