Thread: Poolvergnuegen, pool cleaner, 2 wheell or 4 wheel?
    Im about to purchase this model pool cleaner, suction side and not sure which one to buy. We dont have a large pool, but its 16 x 30 feet, kidney shaped and the skimmer is on one end so I seem to be at the extreme for the 2 wheel so would the 4 wheel one be better?
    Thanks!
    Reese
    22K gal, IG plaster, hayward 1500 pump, DE filter, spa, Polaris 3900
    38,346
    Re: Poolvergnuegen, pool cleaner, 2 wheell or 4 wheel?
    Welcome to TFP!!!
    The 4 wheel comes with a longer hose, but I am not sure if you could add extra hose to the 2 wheel for added reach if needed. I am not sure of the price difference, the 4 would certainly work and the 2 might work or need longer hose.
    From what we hear, either one is a great cleaner.
    Get the 2 wheel, you can buy extra hose (I think I got my extra hose at Leslies). If you buy the four wheel, then you'll need to replace four rubber tire thingies instead of two. Best pool cleaner ever!
    18K Gals, Intelliflo VSD, Pentair Catridge, SWG, Solar & Gas Heat, Pebble Tec, Jandy AquaLinks, Pool Pal for Android.
    Well I ended up buying the 4-wheel one and after watching it a bit, cleans pretty darn well. Only one issue, does not seem to be going up walls hardly at all, kind of hits the slope and turns around. its running at about 12 RPM.
    Any ideas?
