Results 1 to 13 of 13
Thread: Got a lot of rain yesterday and I don't understand my TA test with my TF-100 test kit
    Got A LOT of rain yesterday.
    Using the TF-100 test kit and speed stir, when I tested for TA, I added first the 2 drops of R-0007 and then 5 drops of R-0008 and it turned RED immediately NOT green. I didn't even have to add R-0009 to make it red. So does that mean my TA is way low and I need to add baking soda? I've never encountered this before so I want to make sure what to do.
    FYI - my pH was also low 6.0 or so. That's why I think my TA is real low too.
    comments…?
    10k gal., Hydrozzo finish, in ground chlorine pool, No Spa, No Heater, Built in Oct 2012 • TF-100 test kit • Jandy Cartridge Filter CV340 • Jandy VSFloPro Variable Speed Pump Model VS-FHP2.0 • Hayward TigerShark QC Robotic Pool Cleaner RC9990GR • Intermatic 100 watt Safety Transformer Model# PX 100 • Intermatic Freeze Sentry PF 1202T.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Got a lot of rain yesterday and I don't understand my TA test with my TF-100 test
    The scenario that you described above is correct.
    Do you have test results from before the rain?
    Yes I do. Numbers before rain...
    FC 3.5 CC 0.0 TC 3.5 pH 7.5 TA 70 CH 400 CYA 60
    My plan according to TFP is I'm going to tackle TA 1st, cause that may raise my pH some. Once I hit my TA number I'll tackle pH.
    Is this the right way to go?
    2 more questions:
    1) Once I start adding baking soda, how long do I have to run the pump before I retest?
    2) Does adding stabilizer raise my CH at all?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Quote Originally Posted by martinspool View Post
    2 more questions:
    That's what I'd do - raise TA to buffer things a little, then add borax or soda ash. Play around with http://www.troublefreepool.com/calc.html down near the bottom where it shows Effects of Adding Chemicals. You can see what effect adding the baking soda will have on pH and TA, as well as borax or washing soda. Washing soda will raise TA a bit, which means you won't want to add the whole amount of baking soda initially. Maybe raise TA by 40? Then do the pH. Then fine tune the rest.
    As far as spacing things, half an hour with the pump on should mix things, especially if you go around the pool once with the brush. A wall whale will really get things stirred up, if you have one.
    Stabilizer will not affect CH, only CYA and a teeny lowering of pH. Be aware that you also lost some salt if you diluted everything else that much, so be sure to keep FC up with bleach if you have to.
    38,364
    I think you want to use borax to try to raise the pH first ... that will also raise the TA. If you adjust the TA first, when you work on raising the pH from what may be around 4-5, it will raise the TA higher than you want.
    It is very odd that some rain with cause such a huge drop in pH and TA.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    If it were mine, I'd go Soda ash or Borax before Baking Soda. You will see a pH bump with BS and such low pH, but it wouldn't be my first choice.
    I agree, that would seem to indicate some wicked acid rain, and a whole lot of it. My immediate thought was accidental over feed of acid. Very strange.
    Essential Links:
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    unless your talking tropical storm
    i would consider the rain water was sitting on the surface and hadn't mixed with existing pool water
    try and take a sample deeper in the water or run filter for a few hours and retest
    i would be reluctant to add any chemicals until a second test confirmed results
    just my opinion and i am a newbie by the the way
    so i would listen to the experts but a second test wont hurt
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    38,364
    aussieta, comes up with a great point. Did you circulate the water for at least an hour before testing? Still, I would be surprised that the rain water was that low of a pH and TA
    Mar 2011
    Houston, Texas
    413
    I've tested the pH of rain here in Houston in the past and it was right at 6.8. Hard to imagine it was that low.
    Not sure where you are located, but I'm in the Memorial villages and the TA of my fill water is 220 (although I haven't had to top off my pool in about 3 months) so it's very hard for me to get my TA in the 60-70 range even when I'm trying to lower it.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    I'm currently aerating now to bring my pH up and over the next few days my FC will balance out.
    Here are my current readings as of this morning:
    FC 6.0 CC 0.0 pH 7.3 TA 70 CH 350 CYA 65
    BTW HouTex…
    I'm on the west side of Houston near Katy and my city tap water readings are:
    FC - 0.80, PH - 7.2, TA - 90, CH - 125, CYA - 10
    Thanks everybody again things are good now.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    So, no more trouble with the TA test?
    Essential Links:
    Nop. All fixed now.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Ok, so good to hear that! Time to start getting ready for Summer....
    Essential Links:
