Thread: Liquidator overfilling
    Feb 2009
    35
    I have a commercial liquidator, I can only add about 3 gallons of chlorine to the feeder at a time before it overflows with water. Not sure what is going on. Any help?
    caretaker of over 500,000 gallons of water weekly
    www.youtube.com/lukepoolservice
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Liquidator overfilling
    Just short term and then it levels out? I have to take a break when filling mine.
    you can gently hold the out float up to cut off water then slowly fill, or turn off pump and slowly fill it and let it run down again. Think this is my 3rd or 4th year with liquidator,, compared to other systems it's low tech but once dialed in very solid and very little more adjustments needed or extra "gizmos" to break----- Just what I wanted.
    21000 Gallons I/G,,Vinyl,, 1.5 H.P. Hayward Pump,, Hayward Sand Filter S244T.. Liquidator.
    Mar 2007
    Virginia Beach
    272
    I have found on mine that if you invert a bleach bottle into the funnel it will only drain into the LQ as the level goes down enough to accommodate it. So I refill mine thusly.
    6000 gal inground fiberglass
    1.5hp pump / sand filter
    Liquidator
