Thread: Any thoughts on the benefit of EcoFilter?
    Jul 2013
    Greenwood, IN
    80
    Im in process of changing my filter this spring.
    I have read about the Eco Filter but, cant really find any endorsement outside of the manufacturers site (go figure). I know the zeolite is supposed to be better to and filter to a lower micron however, I wasn't sure if more laterals really made a difference or not.
    Thoughts?
    http://www.ecopoolfilters.com/
    30K gallons, 18x36, Intellichlor IC40 SWG, Sand filter, Intelliflo 1.5 HP, TF 100
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Any thoughts on the benefit of EcoFilter?
    Just looking at the website and making an overall statement, I'd say the claims are probably a little over-inflated. I don't know where they fall in price comparison, but personally, I wouldn't pay more for one than a top of the line trusted brand like Pentair or Jandy.
    Essential Links:
    It looks interesting. However, in a normal pool the filter is not the major source of energy usage. Even if you magically removed all energy used by the filter it would make little difference. It is possible to build a pool where the filter is a much higher percentage of the energy usage, but you essentially never see such pools. So, if you are thinking about upgrading an existing pool filter or getting a filter for use with a normal pool design, getting this one will make little difference. On the other hand, if you are designing a pool from scratch to be no holds barred super energy efficient, then this filter looks worth considering.
