Thread: New pool in Las Vegas
    TS's Avatar
    Jan 2014
    Las Vegas, NV
    3
    Hi I'm new here
    We're about 2 weeks into building our new pool and thanks to lurking on this forum my husband and I are much more knowledgeable about pool construction than most of our PB clients.
    My question is, how tolerant of mistakes are you with your pool build? So far the only problems we've had have been with the plumber. Seems like just about everything he's done has been messed up in some way, from installing the water service on the wrong side of the house tied into the wrong water lines, to not installing the air pipes for the spa because the jets were back-ordered (we didn't find out this one until the gunite guys came by today and said they couldn't do the spa because it wasn't ready).
    Our PB is on top of getting everything corrected and how it should be, but seems to think this is no big deal - "things happen" as he put it. We on the other hand are close to requesting his plumber never steps on our property again. Are we overreacting? We've agreed to meet in the middle and requested the PB be onsite supervising anytime the plumber is working.
    And some pics: first one is digging the hole, second is after the steel and plumbing were installed
    under construction
    38'x20' 19K gal, IG gunite, 7'x7' spa, Pentair variable speed pump, 420 sqft cartridge filter, 400K btu heater, Pebble Sheen finish
    We_Like_It_Hot's Avatar
    Jan 2014
    Las Vegas
    33
    Re: New pool in Las Vegas
    Hi TS,
    Welcome to the forum. Your pool looks great!
    As for the plumber, sounds like you have things under control by requesting the PB be there to oversee his work.
    Hopefully this will be the last of any issues you have during your build.
    Enjoy
    G&D
    Shotcrete 16'x25' rectangular with a half in 7' round spa raised 18" negative edge spillover, med. gray plaster. 9K gal. 3' sheer descent, 8'x12' wet deck.
    All equipment Pentair. 420 C&C, 400K MasterTemp, WhisperFlo 1hp, IntelliFlo, WhisperFlo 2hp, IC40 Intellichlor, EasyTouch Wireless ScreenLogic2 Interface, 3ea. GloBrite LED's.
    Readyforapool's Avatar
    Sep 2013
    DFW metroplex
    738
    Didn't do it with the pool build and probably regretting it due to the leak, but never having built a pool before we were too stupid to know what was right and wrong. We did however, tell the owner of the company that installed our electric driveway gate that his electricians - Moe and Curly, were incompetent and we wanted professionals to come back and check things - they found lots of mistakes that ultimately could have shorted out the whole house!
    Finally Done! - 21x34 IG, SWCG, depth - 3.6 - 4.6 - 6.6, Pentair IntelliFlow 3050 vs+svrs, 60 sq ft Pentair DE Filter, 400k BTU Heater, Polaris 280 w/.75 hp booster pump, Pentair EasyTouch wireless, 38 sq ft raised spa, wet edge Barbados quartz finish - ODK w/36 in Napoleon grill
    Jul 2012
    Oklahoma City
    72
    We have kinda the same thing going on with our build. I am trying to watch as much as possible and ask a lot of questions without being a pain. We both have to live with the end results and the PB is long gone.
    Why did your PB order gunite if the spa was not ready? One day at a time, one step at a time!
    Good luck.
    IG gunite Edmond, OK(OKC), 18x36 freeform ~20K, 4-8' deep, Pentair equip, (2) 3hp VS+ pump, 520 cart filter, 3 LED, Easytouch8, ItellichlorIC40 SWG, Polaris 3900 cleaner, Spa 8'x18"raised, 20' raised bond beam 2 sheers, Stonescape Tahoe Blue quartz plaster, TF-100 kit.
    Feb. 25, 2014 dig started, May 24, 2014 filled.
    TS's Avatar
    Jan 2014
    Las Vegas, NV
    3
    shell is poured. next up tile . . . when it gets here in two weeks
    I didn't know you had to water gunite 3-4 times a day. Learn something new everyday.
    under construction
