Results 1 to 8 of 8
Thread: Hayward Navigator driving me crazy
    Sep 2013
    San Diego, California
    21
    The title says it all. My pool cleaner is a Hayward Navigator. Unfortunately it doesn't navigate. I've had it in Leslie's Pool Supplies. The thing used to scoot around and cleaned the whole pool pretty well. Now, however it won't steer. It just creeps into a corner and sits there. Leslie's have replaced bearings, A frames and gearbox. They don't seem able to figure out what's wrong.
    I have 2 questions:
    Does anyone know what's wrong with the thing?
    If I need to replace it what should I get?
    Thanks
    1) 14,000 gals
    2) DE filter
    3) In ground
    4) concrete
    5) Flow rate of filter; 120
    Location - San Diego, California
    38,472
    Re: Hayward Navigator driving me crazy
    I have never read much good about that cleaner ... to many parts that always go bad.
    The Pool Cleaner (now owned by Hayward) is a highly recommended suction cleaner.
    Feb 2014
    Central California
    17
    Quote Originally Posted by Spiny Norman View Post
    I have 2 questions:
    Thanks
    I inherited a navigator and I've replaced quite a few parts on mine (purchased from Amazon), including the a-frame, turbine kit, pod shoes, & the gear box. As you know there are quite a few parts. Typically, if it isn't steering, they would usually say to replace the gear box but it sounds like you have replaced that already. There are other gears up near the hose connection (medium turbine/spindle gears) which may play a part in steering and the hose connection collar has a gear also. Here is a video that I found helpful (http://www.youtube.com/watch?v=jD9hiFQBthA) and this guy has some others that show you how to disassemble the navigator.
    You mentioned that Leslie's replaced the bearings, assuming the turbine bearings, does it look like the turbine turns freely?
    One test you can try is holding the navigator by the hose under water while the pump is running. The navigator should turn in one direction for a few minutes and then turn back the other way if it's operating normally.
    Now, one other thing I found. When my filter was not working well, pressures were high, I wasn't getting good flow through the navigator and it didn't move well at all. Once I replace my cartridges and my pressure was only 10, that guy is buzzing the pool again. So, if you think that might be an issue you may need to clean the filter or replace cartridges etc. to get the water flow improved.
    Good luck and let us know what you find. If I think of anything else that might be helpful I'll add it.
    18K gal, IG Concrete (colored), Hayward C3025 cart. filter, Hayward Tristar 2-speed 1.85 HP pump, pool is 4yrs old, Hayward Navigator XL vac
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    I'll have to agree with dj_pool! Check suction pressure. My XL came with an L-Shaped Hayward type suction gauge (simple spring type). Adjust the pool/suction valves until the spring-gauge reads above mid to max; mine is just not happy at mid suction or below (hung up too much). Now after I've figured out the tricks, Im completely happy with it.
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    Sep 2013
    21
    Quote Originally Posted by dj_pool View Post
    Thanks, yes the turbine turns freely, in fact they replaced the bearings a few weeks ago so that's all good.
    I did do the test holding the hose and seeing which way the navigator turns. At first it only turned one direction, so I replaced the gearbox myself. But there was no improvement, in fact it doesn't turn either direction now.
    I have the pressure gauge thing and my pressures are mid to high but whatever I change it to doesn't make the Navigator to steer. It just goes straight until the weight of the hose pulls it back, then it falls over and set off again generally in the same direction; or it hits the wall, stops, gets pulled backwards a foot or so then goes forwards and hit the wall gain where it stays.
    1) 14,000 gals
    2) DE filter
    3) In ground
    4) concrete
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    That's odd! I've never had to replace the gearbox-bearings but, a year or so ago, I did open it up (just for a look-see ) and noticed positioning of a small drive gear was crucial; not held in place by any other components when replacing the housing. I used a small amount of silicone lube to hold it in place during reassembly. Sorry but cannot remember exactly which gear it was, but it involved the turning function and I got lucky as it still worked properly.
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Before I went further or trashed it, I would consider this for about $20-http://www.webpoolsupply.com/hayward...embly-axv408p/
    Feb 2014
    Central California
    17
    Here is a nice step by step guide that shows the other gears involved also. - http://www.inyopools.com/HowToPage/h...n_cleaner.aspx
