Results 1 to 8 of 8
Thread: goes straight
    goes straight
    hi members, I have a Pentair great white pool cleaner. the darn think only goes in a straight line. will not spin around like it used to. anyone have a fix for this. I understand its a common problem with this cleaner.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: goes straight
    Welcome to the forum Pete!
    Not sure on that one, but I'm sure someone around here has dealt with that.
    Essential Links:
    Re: goes straight
    Quote Originally Posted by Brushpup View Post
    hey, thanks brushpup. glad to be here.
    Jun 2011
    Long Beach, CA
    2,787
    Re: goes straight
    Can you take apart the cleaner? Could be a gear is either worn out or stuck.
    Re: goes straight
    Quote Originally Posted by ping View Post
    hi, yes I took it apart and replaced most of the gears. is it possible the lift up brush is bad? it seems fine upon inspection.
    Jun 2011
    Long Beach, CA
    2,787
    Re: goes straight
    Did you run the cleaner upside down to see if the lift up brush is working? You should see it working within a couple of minutes after turning it on. If that checks out, you might try calling Pentair to see what they recommend.
    Re: goes straight
    hi, I did do as you suggested, I turned the unit over while submerged and the brush does not come down. I called Pentair, and they said it was the lift brush? I can't see anything wrong with the lift brush. that's why I thought I'd get another opinion.
    Re: goes straight
    Quote Originally Posted by pete g View Post
    hi fellow members, Well I ordered a new lift brush per Pentair, and as I thought, did not cure the problem. its a little dishearting to realize an employee of the company that makes the thing hasn"t a clue. oh well, the beat goes on.
