Results 1 to 18 of 18
Thread: Music Outside
    Jan 2011
    Northern Illinois
    116
    Music Outside
    I am starting to think Spring (hopefully someday it will come) and wanted to improve our music system outside. Right now we just use one of those small Logitech docking stations (like this:
    Logitech S715i) but the sound isn't the greatest and they don't last more than a couple of years. What I would like to do is run speakers out to our deck (attached to the back of the house) and above ground pool/deck (about 50' from the house). Ideally I would like to run the speakers to a Denon AVR-1613 receiver we just bought but not sure how this would work. It is currently hooked up to the TV in the basement and wouldn't be used if the music was on outside. Any advice (such as how to hook it up, how the receiver could be controlled from outside etc) would be appreciated!
    Wil-Bar 27'x54" Quest AGP
    Hayward 1HP Powerflo Pump
    Hayward 256 T Swimpro Sand Filter
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,092
    Re: Music Outside
    Any chance you have an iphone or ipad? It looks like the receiver supports AirPlay, so depending on a few factors you maybe able to stream music from your phone to the receiver.
    Jan 2011
    Northern Illinois
    116
    Re: Music Outside
    Yes...we have an ipod, ipad and Samsung Galaxy S3 phones. So how would it work? Would the receiver have to be left on at all times or is there a way to turn it on remotely? Would I need some sore of switch to switch between the speakers for the tv and the outdoor speakers? Any decent outdoor speakers you could recommend?
    38,295
    Re: Music Outside
    Likely you would have to go to the receiver, turn it on, switch to the appropriate speakers (likely there is an A/B switch on the stereo), and switch to the appropriate input. Then you would have control of the music through your wireless device.
    I have an older Denon that has a second zone for my outside speakers, so someone could be watching TV inside and I could have music on outside using the same receiver.
    Jan 2011
    Northern Illinois
    116
    Re: Music Outside
    Looks like my receiver only has one zone so I'm not even sure I can use it.
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Re: Music Outside
    This is my outdoor build: http://www.troublefreepool.com/threa...r-Stereo-Build
    I just used the amp fed off my TV. I have a seperate volume control outside. Ask any questions you may have!
    IG, 18K gallons, 100' Perimeter, 565 SF surface area, 980sf interior area, Max Length -36', Max Width - 16', Pentair 520 Clean and Clear Cartridge Filter, Stenner Chemical Injection System (Chlorine, Acid Coming Soon) , Pebble Tech - Blue Granite, Pentair variable speed filter pump, Zodiac MX8 Cleaner, Multi-Colored LED Lighting, Travertine coping & Decking, Boulder Water Fall....
    38,295
    Re: Music Outside
    You are right, that only does have a single set of speaker outputs. I am sure you can buy an external switch to select between the TV speakers and the outside speakers. Or just buy a really cheap amplifier to use for your outside speakers with a wireless bluetooth attachment to supply the music.
    Jan 2011
    Northern Illinois
    116
    Re: Music Outside
    I am pretty clueless when it comes to audio.....could I just buy an amp (or something similar) and just connect an ipod and/or Samsung phone to it (bypassing any connection to anything inside)?
    38,295
    Re: Music Outside
    That would be the easiest. You could use just about any amp/receiver and add a little Bluetooth receiver to it to interface with your phone.
    There was a post on here somewhere about a small amplifier (no FM radio or anything) that someone used for their outside music.
    Here is the Bluetooth adapter that you could hook up to any amplifier: http://www.amazon.com/gp/product/B009OBCAW2
    And I think this is like the cheap little amplifier they used: http://www.amazon.com/LP-2020A-Lepai.../dp/B0049P6OTI
    Jul 2011
    Eastern Ohio
    7,092
    Re: Music Outside
    Id look at a soundbar with Bluetooth. You can find one around $150 and they're simple to connect to your phones/iPod. This is assuming that you're able to hide them enough to keep it out of the weather.
    Mar 2013
    CT
    351
    Re: Music Outside
    I agree w Leebo. Check out the Big Jambox by Jawbone. Wireless, rechargeable, and sounds great.
    Sent via Tapatalk
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Jan 2011
    Northern Illinois
    116
    Re: Music Outside
    Thanks for all the suggestions. I'm not sure how a soundbar would work because 1. I'm looking to have music playing on both our back deck (right off the back of our house) and our pool deck (about 50' away); and 2. there is no where protected from the elements on our pool deck (our pool is above ground so deck is raised about 4.5' in the air).
    Jan 2011
    Northern Illinois
    116
    Re: Music Outside
    After further research, I plan on hooking up the speakers to our Denon AVR1613 receiver located in our family room using a speaker selector switch. A couple of other questions:
    1. What kind of speaker wire should i use outside? The wire will be buried in PVC pipe and will be approximately 75' away from the receiver at the furthest point.
    2. Any suggestions on decent, budget outdoor speakers? I would imagine they would have to "regular, rectangular speakers" (not "rock" speakers) as both the back and pool decks are raised at least 3'.
    Thanks!
    Jul 2011
    NY
    51
    Re: Music Outside
    ^ Direct burial landscape lighting cable will work - 14 or 12 gauge.
    29,700 Gallon Vinyl Roman End, Sta-Rite Max-Therm-400HD gas heater, Sta-Rite S7M120 cartridge filter, Pool Pilot DIG-220 SWG
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: Music Outside
    I purchased a PYLE portable PA system. It is on wheels so I just store it in my office when not in use. I have found the weather, sun, and salt water can kill just about any piece of electronics. This thing sounds awesome and it has bluetooth, RCA inputs, sd and usb memory slots, just load up a thumb drive with a bunch of music plug it into the speaker and use the included remote to control it. It also has XLR inputs for a microphone. My nieces love it for singing along. It also works great for yelling at the kids when they run. Highly recommended.
    http://www.ebay.com/itm/like/111007558592?lpid=82
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Jan 2013
    Houston, TX
    1,079
    Re: Music Outside
    You could always get a roomie remote to control the receiver. They also have cool little dongles that do ethernet to IR to control other devices.
    http://www.roomieremote.com/ip-compatibility/
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Willi's Avatar
    Mar 2014
    Florence, KY
    69
    Re: Music Outside
    I have a receiver and two tower speakers in the pool house.
    A neighbor complained last summer a couple times and even called the cops :-/
    Think it is because the speakers are directed toward their house. Bought a couple rock speakers and going to pick up a couple Bose outdoor speakers. Direct burial speaker wire is expensive but well worth the money.
    18' x 36' IG Vinyl 30K gallon, Hayward 1 1/2 HP pump and DE Filter hardpiped, Aqua Pro 1300 Electric Heat Pump.
    TF100 Test Kit on order !
    Commercial Popcorn machine, sno cone machine and cotton candy machine, lost my red nose.
    Jan 2013
    Houston, TX
    1,079
    Re: Music Outside
    Be careful with leaving the speaker selector in outside. Once had a movie night with a r rated movie. Didn't realize the neighbors were having a movie night with us.
