Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Using Trichlor tablets for start up
    mcanchola2's Avatar
    Apr 2013
    San Tan Valley, AZ
    64
    This discussion was split from HERE to avoid hijacking. jblizzle
    I still can’t believe that Shasta did not show you how to do the pool chemistry. We recently had our pool built too out here in Arizona (Completed in January) and our builder (California Pool and Landscape) sent a guy out and showed me step by step how to measure everything. They did give me the cheap test kit. I will buy the TF-100 before the summer hits us. Another funny story about Leslie’s pool supplies they told me I had to use the Tricholr Pucks and not liquid chlorine “because, Arizona does not get enough rain to keep the CYA levels up in the pool.” I just nodded my head and smiled and did not say anything. I am glad I found the forum months ago and knew the guy was lying to me. On a side note I am currently using the Tricholr Pucks the pool builder gave me at startup, but once they are gone I will switch over to liquid chlorine.
    17k IG pool (34' X 19'), Pebble Plus Interior - Artic, Hayward ECO Star Variable Speed Pump, Hayward ProLogic P-4, Hayward 480 Cartridge Filter,
    (2) Jandy Deck Jet's and (1) bubbler, Wave Force Cleaning System, Trident UV sanitation System, TF-100 test kit with SpeedStir
    My Pool Build
    38,251
    Re: New pool startup in AZ
    Quote Originally Posted by mcanchola2 View Post
    This may not be a good plan. What is your CYA currently? How many pucks are you planning on using?
    If your CYA is range, you would be better off saving the pucks until you need to raise the CYA some and start using bleach now.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    + 1^^^^. I was just going to say the same thing.
    Jeff
    mcanchola2's Avatar
    Apr 2013
    San Tan Valley, AZ
    64
    well I guess I am going to have to buy the TF-100 sooner than later to get my CYA readings. I will buy it once I get home from work. I am on my 5th puck and my FC level is at 4, My PH is at 7.6 and my TA is 110. These are the readngs from the test kit that my pool builder gave me. I have not taken my water to a pool store, not sure I will trust them to be honest.
    My Pool Build
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Get the kit and test your own water. You can use pool math, at the bottom Effects of Adding Chem's. to give you an idea how much each puck is increasing your CYA level.
    You DON'T want to over shoot that level.
    Jeff
    38,251
    Assuming you pool is around 17k gallons, each puck raises the CYA by about 2ppm and the FC by 3.2ppm. Was there any stabilizer added during start up? If not, you are only up to around 10ppm on the CYA (and honestly I would be surprised that you still have a FC level of 4ppm). So, my guess is that stabilizer was added previously because if not, the sun would likely burn up the FC faster than the puck would be adding it.
    38,251
    Re: Using Trichlor tablets for start up
    Please add your pool details to your signature as described HERE as it will help us help you.
    mcanchola2's Avatar
    Apr 2013
    San Tan Valley, AZ
    64
    Yes there was stabilizer added at startup. And the pool is around 17,000 gallons
    My Pool Build
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Did You order the TF -100 ? If you didn't I recommend you do. When the kit comes test your CYA level. That's why you have to watch using the pucks till you know where that level is. Get the kit and post your test results.
    Jeff
    mcanchola2's Avatar
    Apr 2013
    San Tan Valley, AZ
    64
    Sounds good, the kit had been ordered
    My Pool Build
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Good job 👍. Your CYA level may be ok. You just want to confirm what it is so you don't get it too high. PITA to get it lowered if ya know what I mean. 😎
    Jeff
    mcanchola2's Avatar
    Apr 2013
    San Tan Valley, AZ
    64
    Yes, I do not want to drain a brand new pool, that would suck
    My Pool Build
    mcanchola2's Avatar
    Apr 2013
    San Tan Valley, AZ
    64
    I bought the TF-100 and got the XL option and the magnetic stirrer as well.
    My Pool Build
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Good job ! You won't regret it and the speed stir is a nice little upgrade to it. Must have been pay day yesterday. LOL 😎
    Jeff
    mcanchola2's Avatar
    Apr 2013
    San Tan Valley, AZ
    64
    lol, it was but I can afford the nice things in life every once in awhile AKA a speed stir, lol. If I am going to be the pool boy I might as well have a cool test kit
    My Pool Build
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    The right tools for the job no matter what the cost. LOL.
    Jeff
    mcanchola2's Avatar
    Apr 2013
    San Tan Valley, AZ
    64
    Went to the pool store today and got readings from them. (I am still waiting for my TF - 100 to show up)
    FC - 3
    TC - 3
    CH - 210
    CYA - 70
    TA - 100
    PH - 7.5
    According to their test my CYA is a little high. They also said the my phosphates were high. I am guessing that is what they were told to push here. because everyone that goes there is told their phosphates are high.
    My Pool Build
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    No need to worry about phosphates.
    Let's compare when the TF-100 arrives. With those results your FC is low for the CYA level. You should be no lower than 5 ppm FC for that CYA level. http://www.troublefreepool.com/conte...art-slam-shock
    Jeff
    mcanchola2's Avatar
    Apr 2013
    San Tan Valley, AZ
    64
    I just did the pool calculator and I am going to add some more liquid chlorine now, to get it up to 5
    My Pool Build
  20. Back To Top    #20
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I would go to at least 8. 5 is the bare min. Hopefully the kit will arrive shortly and you will have an accurate way of testing.
    How does your water look, just out of curiosity.
    Jeff
