Thread: Is my Jandy checkvalve faulty? flap halfway open (pic)
    Feb 2014
    CA
    24
    Photo taken below at full RPM. The flap does not open all the way up (maybe half way - if that). Are these suppose to swing wide open?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Is my Jandy checkvalve faulty? flap halfway open (pic)
    Normally the flap will be against the plastic cover with water flowing.
    I'd take it apart and see what's going on.
    38,343
    I have never seen the flap all the way open ... it is a pretty stiff spring. Unless you have a very strong pump and high flow rate, I think what you are seeing is normal.
