Results 1 to 7 of 7
Thread: draining pool
    May 2013
    Mesa, AZ
    7
    draining pool
    have a few questions am thinking of draining the pool due to the pool is starting to have tiny floating particles nad i dont know how long it has been since anyone drain the pool. am going to do a filter replacement on the cart. and also replace the light bulb with a led bulb, so i figure i would drain the pool because am also going to soda blast the calcium on the tiles.. my other question is should i acid wash or chlorine was the pool because ive heard people not recommend to acid wash a pebble tech pool unless you really need to.
    once all that is done what should be the first steps to bringing the chems back once a fill the pool. or should i not drain the pool at all?
    10K gallon IG, pebble with waterfall; Pentair cartridge filter; 1 1/2 HP pump; Eco Matic SWG Zodiac Cleaner
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    Re: draining pool
    You may not need to completely drain the pool. Post a complete set of test results and we can help you determine the best course of action.
    Love TFP? Become a
    TFP Supporter!
    22,553
    Re: draining pool
    In Mesa you probably don't have to worry about the water table, however there is hardly ever a need to drain the pool just because of "floating particles". There may be a reason but particles in the water is a filtration/circulation or sanitation issue not a "old" water issue.
    As Zea said, a full set of test results on the pool water, and all but CYA on the fill water, would give us an idea of where you need to start.
    May 2013
    Mesa, AZ
    7
    Re: draining pool
    ill post my water test. had another question is there any good chemical that would work good to take calcium line because I really don't want to sand blast
    22,553
    Re: draining pool
    An acid wash would get it, but that's no better than blasting.
    May 2013
    Mesa, AZ
    7
    Re: draining pool
    I thought acid wash won't get the calcium line on the tile
    22,553
    Re: draining pool
    You can use diluted acid to remove it, but like I said, that's not really a better option.
