Results 1 to 13 of 13
Thread: Fibretech fiberglass pool problems
    digidutch's Avatar
    Feb 2014
    Tampa Bay area, Florida
    15
    Live in Tampa Bay area Florida. Have had Fibtretech pool for 11-12 years. Lately chemical balances off. Pool sides and bottom look brown. Tried the Vit C method which clears it. Chemical levels way off. Where to start, first do the ascorbic acid/Vit C.? How to proceed. Its way too acidic. Do I add Soda Ash first, chlorine or shock.
    I would actually just like to resurface to pool. Does anybody know a reputable company in the Tampa Bay area and what would be the recommended surface.
    May questions I know, hope for some advice. thanks
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Fibretech fiberglass piece of sh..
    Welcome to TFP !
    Can you post a full set of test results ? With out some reliable test results it's going to be hard to get you started in the right direction.
    Do you have your own test kit ? If you have a kit what type of kit are you using ? If you don't who is doing your water testing ?
    These are the test kits that we on the forum recommended I personally use the TF-100. http://www.troublefreepool.com/conte...its-comparison. If you don't have one of these kits I highly recommend you get yourself one. If you want to maintain your water chemistry balance it's a must have. Accurate water testing is one of the key's to a trouble free pool and the results from one of these kits are the ones we trust.
    Can you take a picture of your pool. That could also help us out. Also if you add all your pool and equipment info to your sig it will help us help you better. 😎
    Jeff
    digidutch's Avatar
    Feb 2014
    15
    Re: Fibretech fiberglass piece of sh..
    Am getting test kit and will work on the equipment as well as a photo or 2. This forum should help me get this pool under control. Thanks
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Good job ! 👍 When the kit arrives post up the results so we can see what's going on and get you pointed in the right direction. 😎
    Jeff
    digidutch's Avatar
    Feb 2014
    15
    thank you
    10000 Gallon, Fibretech InGround fiberglass. Sta-Rite Posiflow II cartridge filter. Baracuda G3 suction cleaner in skimmer port. Pump is 1 HP because needed extra power to get H2O up to Solar Roof Panels which we no longer have.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    No problem ! 😎
    Jeff
    digidutch's Avatar
    Feb 2014
    15
    Ok here are my numbers. Looks like a mess.
    FC 11.6
    CC 0.2
    TA 80
    Calcium Hardness 310
    CYA HIGH at about 150
    Fiberglass pool, 10000 gallon
    So..... should I increase PH to 7.5 with soda ash, SLAM, replace water Where should I start.
    Thanks in advance
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Since your CYA is so high you need to drain and replace water first, then adjust pH, do the ascorbic acid treatment to remove the stains, have the water tested for metals, if positive add sequestrant, then balance the water. Do you know if your source water contains metals?
    Love TFP? Become a
    TFP Supporter!
    digidutch's Avatar
    Feb 2014
    15
    Thanks for your fast response. I have no clue where the metals would come from. Only netal is the ring around the pool light. Water is from city, very clean source. I figured to drain. It is going to rain a lot today that should help. After doing the Vit C the pool actually looks much better. Never added sequestrant to it. Thanks and I will report how things go.
    digidutch's Avatar
    Feb 2014
    15
    Okay, drained water from pool.
    Numbers:
    FC 12
    CC 0.5
    PH 7.4
    TA 110
    CH 300
    CYA 100
    Still High CYA but pool looks much nicer, clear and the brown stains are much less. I added AA and Stain remover.
    Trying to see if Metal Filter would make sense to use as needed.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I would still replace more water to lower your CYA level. If you can get it down to 40-50 ppm that would be good. When you get into the full sun in the summertime you can always increase the CYA level a little to help protect your FC from the sun.
    Your using liquid chlorine correct ?
    Jeff
    digidutch's Avatar
    Feb 2014
    15
    Re: Fibretech fiberglass pool problems
    Yes, now I do. Used trichlor pucks always due to ignorance, now I know better. My Pinch&Penny guy told me most people use puc s in summer but not during cooler months as to not increase CYA. He actually seems to know his stuff after talking to him. I am learning daily things I should have known for years.....
    Will drain more. I will be out of town few days so will work on it when back. Thanks for the responses, greetings. Raymond
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Sounds good 👍. When you get back let us know how things are going. I think your starting to get a good feel for things. 😎
    Jeff
