Results 1 to 7 of 7
Thread: Pump Size
    Jan 2014
    Fredericton, NB, Canada
    130
    Pump Size
    Hi guys...I'm just about to purchase my new pool kit and am just making a few last minute decisions. Pool is 18x36 kidney shape, 22000gallons. 30" hayward Pro Series 30" sand filter (2" top mount), and Summit SUM5 heat pump. I was going to purchase the Hayward Super Pro 2HP single speed pump but the salesman told me that the 1.5 HP is definitely sufficient for my set up. Do you guys agree, or would you recommend the 2HP super pump? I have no other features such as waterfall, slide, spa....just the pool.
    Thanks as always for the help!
    22,553
    Re: Pump Size
    Actually a 1 hp full rated 2-speed would be a better choice.
    Jan 2014
    130
    Re: Pump Size
    Really?...a 1HP is sufficient for this size pool with heat pump? On the same note, is the low speed of the 2 speed pump going to be sufficient when I need to run the heat pump?...or would I just need to run full speed whenever the heater was used?
    Thanks for the help!
    Jan 2014
    130
    Re: Pump Size
    Are you recommending the Hayward TriStar full rate 1HP 2 speed pump? Or the Hayward Super II 1.5hp Max Rate 2 speed pump?
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Pump Size
    Hello,
    A two speed is usually always recommended over a single speed for energy savings. It's always better to run on high when heating the water, with that said, some heat pumps you can adjust the pressure switch so it will run on low, or at least start on high and switch down to low.
    Will you be using a cover at night? Otherwise it's like heating a house without a ceiling.
    Looking forward to seeing your setup.
    22,553
    Re: Pump Size
    Quote Originally Posted by coreyadam View Post
    Either of those should work well. I'd probably go with the TriStar but I don't really have a convincing reason why.
    You could try to run the heat pump on low and if it works, great. If it doesn't, just switch to high during the heating cycle.
    Jan 2014
    130
    Re: Pump Size
    That's great guys...i appreciate the input! I will definitely be using a solar cover every night and day when it's not in use. I will absolutely post pics when it's finally set up....but that won't be until middle of May Let me tell ya...the time can't go by fast enough!!!!!
