Thread: refill in pool
    Jan 2010
    Claremont california
    100
    refill in pool
    Hi!
    I just finish cleaning my 30k plastered pool. I wanted to know if there is a good procedure to add the chemicals? In the past, I just added the 8 pounds the home depot brand conditioner tied up in a sock inside my skimmer.
    Please advice, if there is any more chemicals need adding and it's procedure?
    I welcome any input!
    22k plaster pool kidney shape. Pentair 4000 de series 48 ft. 2 SKIMMERS, 2 drains (pool and spa), 3 returns (2 pool and 1 spa) gas heater and pentair intelliflow , Underwater pentair light.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: refill in pool
    Hold off on any chemical addition for just now.
    Contact the installer immediately to see if they have parameters for you to follow.
    This is to avoid losing any possible warranty they off on the plaster if you
    "do something wrong with the chemicals". You don't want to leave that door open for them later. Let us know, then we can help.
    Essential Links:
    Jan 2010
    100
    Re: refill in pool
    I understand! I forgot to mention that the pool replaster is six years old. I bought the house five years ago. Does the warranty extends to me?
    Please advice,
    G.
    38,251
    Re: refill in pool
    You would have to ask the builder if the warranty extends to you or not. At this point, I would assume not and just start by testing the pool's chemistry and seeing what needs adjusting. You will certainly need to get some CYA and chlorine in there right away.
    Which pool are you talking about? Your Sig says a 16k vinyl and a 6k something. If you are talking about the 6k pool, 8 pounds of CYA is WAY too much.
