Thread: Muratic Acid How Soon To Test After Adding
    May 2008
    Louisville,KY
    59
    How long should it take for a p.h. change to show up after adding muratic acid? I used the liquid type, added it to a couple gallons of water, and broadcast at deep end returns. I used 16ozs ,as I was only looking for a .3 reduction.
    16x32 IG vinyl
    24000 gallons
    Hayward super pump 1.5HP
    Hayward Pro Series Filter S244T
    3 returns, bottom drain, skimmer
    Re: Muratic Acid How Soon To Test After Adding
    I always wait overnight, as I want to make sure and not overshoot PH on the low end.
    I suppose you could go by your calculated turnover time at a minimum, if you're in a hurry for some reason.
    Mar 2007
    San Rafael, CA USA
    12,082
    Depending on your pool's circulation, the pH change could be reflected in 20-30 minutes though I'd wait an hour to be sure. Most chemicals mix thoroughly in the pool rather quickly and the reactions in the chemical buffer system are very fast (in human terms). The only exception would be "thick" viscous products like PolyQuat 60. I've done tests in my pool that show fairly thorough mixing in 20 minutes when pouring chemicals over a return flow at the deep end, but I've got two floor drains and a skimmer opposite the return at the deep end and two additional returns in the shallow end. For above-ground pools that typically do not have a floor drain, the mixing will take a lot longer though you can speed things up by lightly brushing with a pole or otherwise stirring up the water.
    Richard
    My pool usually reflects pH changes after 90-120 mins.
    2003 Marquis Euphoria - 400gal
    Jun 2008
    Thornton, PA
    76
    Quote Originally Posted by chem geek
    I guess another exception to the 'test it quickly after adding' rule is CL stabilizer/ CYA -this stuff takes up to a week to be testable -from what I've read here.
    Dan
    28K Gal. 802 Sq Ft., Free Form, IG, Gunnite with Midnight Maui Hydrazzo Carlton Pool. Exposed Aggregate Decking. Jandy DE Filter, 1.5 HP Jandy Pump, SWCG. Zodiac 380 pressure-side cleaner. Completed Construction: May 2008.
