Thread: Cleaning and vacuuming
    Feb 2014
    Dallas, TX
    77
    So thanks to this site I think I'm ready to take the plunge (pun intended) and take over my pool completely. I've got my chemistry under control, freeze guard installed, performed backwash and refill cycle with my DE filter and have a Stenner pump going in the weekend.
    The last thing I need to get down is cleaning. I have a leaf rake that I've been using but have yet to brush or vacuum. The brushing seems pretty straight forward, just brush the plaster to free up any dirt to be picked up by the vacuum or Polaris. My question is on the vacuuming. I think I have all the equipment. Hose, poll and vacuum heads. From what I understand I pull out the skimmer basket, plug one end of the hose into the skimmer pipe and the other end onto the vacuum head. But if I do that what catches the leaves? Without the simmer basket wont they all get pulled into the pump basket? That's not very big and I'd think it would clog easily. I also have two vacuum heads and I'm not sure which to use
    One round
    and one rectangle with rollers on each side.
    Is one better than the other or are they used for different purposes?
    Tom,
    22k IG plaster pool, Haywood DE6020 Pro Grid DE filer
    Century Centurion 2 HP single speed with Challenger Pentair front housing replacement. Polaris 280 and Polaris PB4-60 pump. Stenner Injection
    Pool is probably 1980-1990 vintage. Concrete deck
    30,431
    Re: Cleaning and vacuuming
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Yes, you'll pick up leaves. That's why there's a basket in the pump strainer. You could also get a leaf canister that fits inline. If your skimmer has only one hole in the bottom, you can get a vacuum plate that sets in there, in which case the leaves will get caught in the skimmer basket. http://www.troublefreepool.com/conte...pool-equipment has pictures.
    I've never seen one of those round vacuums.
    The round one isn't exactly a vacuum. I have one. You connect it to your garden hose and there's a net that goes on the top. The water pressure creates a current which runs through the net sucking up leaves and such. You can use that first to clean the leaves off the bottom, then use the second one to vacuum up the fine stuff.
    http://www.amazon.com/Pool-gulper-Va.../dp/B007Q6G4HY
    20,000 gal in-ground plaster pool with sand filter. Replastered recently. Mostly adding bleach and acid. CYA was high when I took over.
