Thread: Tool to change the dome O ring on Hayward sand filter S200 S200KT
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    My top was leaking most of last year and someone previously had tried to silicone it so I knew it needed replacement. I didn't mind the price of the O ring but the spanner tool P/N S200KT was four times the O rings cost. Normally I love to buy tools but I don't think I'll be doing this again. I ran across a Culligan water filter housing wrench P/N SW-3A at Fleet Farm and wondered. It was only five something so I bought it and amazingly enough it works. It only has six "cleats" where the dome has twelve but they engage properly and I was able to spin the top off so I can clean it up and reseal it with the new O ring properly.
    Attachment 27643
    Attachment 27644
    Solar Blanket, Well Water, Borax Added. 68
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Tool to change the dome O ring on Hayward sand filter S200 S200KT
    +1 Someone will find that information useful eventually!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Ended up using it again after reading about how much sand a filter should have and measured the level of mine. I'm a bit low.
