Results 1 to 9 of 9
Thread: 240v timer
    Jan 2013
    Houston, TX
    1,079
    240v timer
    I added some additional automation on the Intermatic 653 and had to move my stenner to an old mechanical timer (T104 I think). I'm looking at the digital option for 240v (my stenner is 240v) and contemplating the P7103ME. Anyone else have other suggestions?
    Thanks!
    Chris
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Jan 2013
    Houston, TX
    1,079
    Re: 240v timer
    Just ordered the P7103ME ... I'll report back on its use in a stenner world.
    22,548
    Re: 240v timer
    Sorry I didn't see this sooner.
    Just be aware that the clock on the 7103 is 120 volts. You may already know that, but wanted to bring it up just in case.
    Jan 2013
    Houston, TX
    1,079
    Re: 240v timer
    Bama,
    I saw conflicting info on that and how it was wired (even on the intermatic site). Have you seen one in person? I'm curios if the clock is wired separately at 120 or if it makes use of one leg of the 240 input.
    Chris
    22,548
    Re: 240v timer
    To get 120 you have to have a neutral, so while you can use one of the hot legs of the 240 volt circuit you need to run a neutral along with them.
    Jan 2013
    Houston, TX
    1,079
    Re: 240v timer
    Just had the opportunity to open the box with the P7103ME. As long as you have a neutral available at the box you are good to go. The timer is indeed 120, but the wiring is internal to the unit and a schematic is provided to wire it up in a 240V world. Pictures to follow.
    Jan 2013
    Houston, TX
    1,079
    Re: 240v timer
    Jan 2013
    Houston, TX
    1,079
    Re: 240v timer
    Re: 240v timer
    Going into year 3 with mine....love it!!!
    Sami
    16,000 IG, SWG, 175 sq. ft. cartridge, 1.5 hp pump, vinyl, Charlotte NC
    TF-100, Pool School, Pool-Calc
