Thread: pentair ic40 and Jandy iaqualink
    May 2013
    Naples, Florida
    9
    I have all Jandy equipment including the new iaqualink. Unfortunately, I have not heard anything good on Jandys Salt water chlorine generators.
    I have heard great things on the I40 by Pentair. Will this integrate with my Jandy?
    Thanks!!
    12k gal, IG, Pebble, Circupool SI45SWG
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: pentair ic40 and Jandy iaqualink
    Hey Roy,
    Just wanted to welcome you to the forum. I'm more of a chemical than equipment guy. Someone will be able to answer this pretty easy for you though.
    Welcome to TFP.
    Essential Links:
    Sep 2012
    Lake Nona, Florida
    386
    Quote Originally Posted by RoysPool View Post
    Thanks!!
    Our pool guy said the same thing about Jandy SWCG so we have an iAqualink and an IC40. The I40 is completely manual. It is wired through the pump relay to come on with the pump. We set the duty cycle in increments of 20% by hand. It works.
    7500 gal gunite/stonescapes, iAqualink RS-8, Jandy 2HP VS-Flopro, Jandy 200 sqft Cartridge filter
    Pentair Intellichlor IC-40, Zodiac MX-8, Fafco solar panels
    DreamMaker X-500 Spa
