Thread: Identify this Hayward Filter
    Mar 2012
    Maryland
    87
    http://fredericksburg.craigslist.org...298646222.html
    I'm looking to get this. I have a 24' round pool (roughly 14,000 gallons). The filter I have (I was told) is too small. I'm supposed to have a 2.6sq ft filtration rate. The filter I have is only a 1.2 sq ft.
    Thanks
    13,500 gallon above ground round pool. Vinyl Liner. Hayward S244T 3.1 cu ft sand filter. Hayward Powerflo 1HP pump (single speed induction). HTH 6-way test kit.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Identify this Hayward Filter
    It's an older Hayward, but you can likely still get parts. It should be more than plenty of filter and might be a good buy at the right price. If too high, I would get a new one if you have that option. I agree that 1.2 is too little for your pool. I'd want more.
    Essential Links:
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I have a larger version of that one, it came with my pool, seems to work fine. If you get it be sure to empty the sand out before moving it, do so carefully to avoid damaging the laterals.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
