Results 1 to 10 of 10
Thread: What are my options here?
    Exclamation What are my options here?
    I'm a CPO, but I have zero experience with building pools/spas. I've only worked on the public pool and spa at work.
    Is this worth fixing up or is it better to just rip it out of the ground, pour concrete and buy a used above ground spa from Craigslist or something?
    -38,000 gallon pool and 1600 gallon spa
    -Triton II TR140 sand filter
    -In ground
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: What are my options here?
    Where are you located ??
    Have you tried the pump to see if it starts up ??
    If you're some place that doesn't hard freeze you need to clean it out and get some water in it and judge it's performance.
    It looks like **** now but with some pressure washing and a coat or two of paint it might be nice.
    Or rip it out and fill it in.
    Solar Blanket, Well Water, Borax Added. 68°
    22,549
    I see what looks like some serious cracking and deformations.
    Depending on what shape the plumbing and equipment is in, I might be inclined to tear it out and buy a standalone unit. Either that or tear it out and replace it with a new built in unit of the same size.
    Wow! My dad and I used to install in ground spas back in the 80s (Kohler) but I haven't seen one in a while. Cracks could just be gelcoat, does the shell feel sturdy or does it deform with weight? Do you have access under spa for plumbing? I have seen some installations where no access was possible. Then, you just need the heater, pump and everything else to work...No biggie!
    Blaine
    50' x 22' 27k gal shotcrete freeform, 2hp 2 sp Pentair Whisperflo, Pool Pilot RC-52 SWCG, Pentair TR 100 sand filter, Prowler 820 robot, Florida Sunseeker LED lights.
    My pool build:
    osage-hills-pool-build-t50526.html
    The spa only has one pump and in that electrical panel, there's a timer. I'm guessing it's for the filter pump.
    What about pump for the spa jets? Does it use the same pump?
    I also need a new electrical panel that has space for at timer in it. Are these special boxes or do you have to get them through a pool/spa parts vendor?
    -In ground
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    The dura-glas pump is pretty bullet proof, you can just replace the motor and be good to go. If it's an intermatic mechanical timer those things are also pretty bullet proof. Can you provide a picture?
    Yeah, I'll go back over there and take some more pictuers. That electrica panel was pretty beat up, though, and the timers were not working. How about the filter? Do they still make cartridges for these ones? They're Sta rites
    -In ground
    Quote Originally Posted by Pcmaker View Post
    Is there a filter in there now? If so, have you tried cleaning it? Otherwise, just have to get the model # and info and look online for new filters.
    Blaine
    My pool build:
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Not sure what you mean by the electrical panel being "beat up", but if it's a matter of rusty appearance, dents, or a door that doesn't stay closed, those are things that wouldn't prevent you from testing the really important parts of your system. Most timers have an override switch, in the timer box, so you can turn the pump motor on regardless of whether the clock part of the timer is working. If you really want to see if the existing equipment can be brought back to life, then I'd clean the filter as other's have already suggested and clean out the gunk in the spa itself, fill it with water and turn on power with valves in the correct positions. Then you'll be better able to access whether you should invest any more money.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Any updates on where you're at with the project ??
