Thread: Chlorine degradation
    Sep 2007
    So here is a question for you chemistry folks.
    It usually takes ~1.5 gallons of 6% chlorine/day to maintain my FC. If I added 4.5 gallons every 3 days would it be equally effective?
    Our pool-
    20x40 Free Form Gunite (3'-8'), 26,000 G, AutoPilot Salt Chlorine Generator SC-48, Aqua blue pebble sheen, Textured Sundek, Pentair Easy touch with remote control, 1hp Sta-Rite Max-E-Pro pump, Max-E- Therm heater 333k BTU, System 3 Mod Media Cartridge filter, and Polaris 380 cleaner with booster pump
    Re: Chlorine degradation
    Based on the information presented my answer is no.
    Adding potentially 3 days of chlorine leaves a large amount of the residual unprotected by CYA and will most likely be lost to the sun. When this happens the chances that the FC will drop to low during days 2 & 3 could allow organics to proliferate, leading to increased chlorine demand when you add again on day 4, leading to a cycle of less and less chlorine available and more and more problems.
    No, won't work.
    Sunlight destroys a percentage of your chlorine. So, the amount of chlorine lost per day is mostly a function of how much chlorine is in the water. If you raise the FC level extra by adding a triple dose of chlorine you will dramatically increase the amount of chlorine lost in a day.
