Results 1 to 17 of 17
Thread: Weather Station & Pool Temperature Sensor
    Jun 2012
    Lafayette, Ca / USA
    260
    We're looking for a Weather station (indoor/outdoor temps, humidity, et al) that can allow a Pool Temp sensor device/hookup. Have done some research - found Oregon Scientific that seems to provide these features. Expensive($200+) and the floating Sensor seems to have common complaints of Leakage after 6-8 months (seal issue). But they DO seem to have the compatibility thing all figured out for multiple sensors.
    Anybody have a suggestion for such a unity & sensor ? I don't like the idea of having to replace the floating sensor every year @ $45 .. Secondly, other than a floating sensor, what other options might we have? I don't necessarily like the idea of a unit floating around the pool - probably will constantly be catching it at the skimmer.
    Thanks everyone.
    30,000 Gal FIBER GLASS (over Gunite Plaster) Pool, Dolphin Nautilus PLUS Robot, (2) Cartridge Filter System (old), 1/2 HP Pump, Full Sun, Solar Heated, TF-100 Test Kit.
    Jun 2012
    Lafayette, Ca / USA
    260
    Re: Weather Station & Pool Temperature Sensor
    I'm surprised - nobody uses a combo Weather Station & Pool Temp Sensor ??
    Feb 2011
    Petaluma, Ca
    665
    I bought the oregon scientific station with the water temp sensor about the time I put in my pool. The water sensor died after 6 / 7 months and with the auto cover closed it would not always connect to the station. The other weather sensors all still work and its been about 3 years.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Jun 2012
    Lafayette, Ca / USA
    260
    Thanks for the input ... Yea, that's what I've been reading - the Pool Sensor leaks. I've sent 2 emails to Oregon Scientific about the issue and they don't care to reply.. So I'll look at other companies. I don't like doing business with companies that just don't CARE.
    Jul 2011
    Northern KY
    38
    If you are a techie/DIY'er, you could look into a Raspberry Pi or Arduino board and you can build your own sensors and have them communicate back to you and/or store your data. I have a friend who just built an Arduino board that monitors the current, temp, humidity...etc on his geothermal HVAC and it notifies him via text message when things go wrong. I'm sure you could find sensors for your application that would communicate with the board.
    http://www.makeuseof.com/tag/arduino...puter-for-you/
    Certainly not turn-key, but I thought I would mention it!
    -Bryan
    _________________________________________
    18x40 oval 25,000 Gallon In-Ground SWG Pool
    Pentair IntelliFlo VS+SVRS pump
    Sand Filter
    Rheem 8350ti Heat Pump
    Jun 2012
    Lafayette, Ca / USA
    260
    Yea, not THAT "diy" ... lol ... but Thanks ... I need to keep Google Searching .. I'm really looking for a floating Sensor that won't Leak and need replaced once a year - and communicates with a Base Weather Station.
    Thanks again.
    38,547
    The pool water temp sensors for most all the automation systems are inserted through a hole in one of the PVC pipes on the equipment pad and is wired to the controller. There is nothing floating to start to leak, just an o-ring that seals around the hole in the pipe. Not sure what it would take for one of the weather stations you are looking for to be able to use one of the typical pool water temp sensors.
    Jun 2012
    Lafayette, Ca / USA
    260
    Yea, I've stumbled across that .. They're called "Linear Pool Temp Sensors" or something like that ... All I've found so far is the Sensor that has the wire - I assumed it screwed directly into a PVC pipe in the system.... I can't find any instructions on everything required though to make it work ... e.g., What does the wire plug into? What is the Base Station used & how does it communicate with the Wire & Sensor ..?? Anyone have a link to the HOW TO Install both components ? Is it a DIY job ??
    Thanks so much.
    38,547
    There is no real communication for the temp sensors, they are just thermistors. The temp changes causes a resistance change. The same senors are also used for the air temps.
    To install the sensor, you just drill a hole in the pipe, stick the sensor in with the oring on it and use a pipe clamp to hold it on. There is a pair of wires connected to the sensor and the other end of the wire is just 2 bare ends that attach to your "controller" which just measures the resistance across the sensor and based on some table can then state the temperature.
    Jun 2012
    Lafayette, Ca / USA
    260
    OK, but then what is the "process" to install a Weather Base Station in the house that detects/displays the Pool Temp ? Does it "read" that inline sensor somehow? I've seen these in various homes ... Sorry for the stupid questions. Thanks
    38,547
    I don't know anything about weather stations. I was just explaining how most pool water temp sensors work ... up to you to figure out how to integrate it into something for what you are looking for.
    Jun 2012
    Lafayette, Ca / USA
    260
    Thanks ...
    Feb 2014
    Dallas, TX
    77
    I just ordered the Ambient Weather WS-10 and the add on pool sensor. Ill report back when they arrive.
    http://www.ambientweather.com/amws10.html
    http://www.ambientweather.com/amf007pf.html
    Jun 2012
    Lafayette, Ca / USA
    260
    Wow ...Great ... Let me know what you find out... Thanks so much !!
    Feb 2014
    Dallas, TX
    77
    Quote Originally Posted by cody21 View Post
    Got it in yesterday. Once I got all the sensors synced up it seems to be working well. It comes with 3 weather proof remotes and I got the pool remote add on.
    Here us a pick if the base and one of the remotes.
    The top is the pool, 2 is upstairs, 3 is outside under the pergola and the bottom rotates between the base and the 3rd remote sensor.
    Here is the thermometer in the pool
    Tom,
    22k IG plaster pool, Haywood DE6020 Pro Grid DE filer
    Century Centurion 2 HP single speed with Challenger Pentair front housing replacement. Polaris 280 and Polaris PB4-60 pump. Stenner Injection
    Pool is probably 1980-1990 vintage. Concrete deck
    Jun 2012
    Lafayette, Ca / USA
    260
    Too bad there isn't a TIME/CLOCK function on the base unit ... That's probably the only thing missing IMHO ... But the price is certainly right @ $53 ... And Oregon Scientific refuses to answer my emails ... So not interested in spending $300+ for their system if that's the kind of support to expect. I'll probably just go with this set up .. Thanks so much !!
    Feb 2014
    Dallas, TX
    77
    FYI the pool thermometer was an extra $25. With shipping the whole thing was about $85
    Support was great. I was having trouble getting the sensors to link. I called and got a human right way and he walked me through it.
    Tom,
