Thread: Best submersible pump to keep pool level in check under cover?
    May 2013
    Fort Lauderdale, FL
    423
    I have an ancient pump that I can drop into the pool to keep the level in check under my looploc mesh drain cover, but it takes hours to drop the level a couple of inches. Is there a good, high flow 115v pump I can leave in there? I'm wondering if I should get one with a built in float switch, then I can leave it on my steps at the right level (15" below deck edge), or just drop it in when needed. If it's always submerged, it shouldn't freeze up in cold temps either.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Re: Best submersible pump to keep pool level in check under cover?
    I love a good automatic cover pump, but none of them are perfect. I have had five or six brands now, and they all seem to last a year or maybe two before failing. I am currently using a Wayne WAPC250, which tends to fall over, and so stop being automatic and is also more prone to trip the GFI than others. I have had three Rule H53SP-24 which work wonderfully, but none has lasted more than a season. The Little Giant 5-APCP lasted two seasons, but can't be allowed to freeze and leaked oil into the water when it failed.
    May 2013
    Fort Lauderdale, FL
    423
    Thanks, I ordered the WAYNE 1/4 HP Automatic High Flow Utility Pump (EEAUP250). It's like the cover pump without the mesh thing and it's cheaper. Since it'll sit on the step under the cover, it should do the job.
    May 2013
    Fort Lauderdale, FL
    423
    Update- I got the pump in and put it on the second step. The pool was full to the tile line again from all the snow we've had. With the 1 1/4" discharge hose, this thing rocks! Pool pumped down in a few hours. Now it's all automatic and I don't have to worry about the water level for the rest of the winter. I just hope it doesn't break from freezing....
    May 2008
    Northern California
    71
    I don't know if this will apply to your situation, but thought I would throw it out there anyway.
    I have a similar Wayne pump (model VIP50), but I only used it when needed and kept it in the garage otherwise. I checked it a couple months ago and noticed that it was leaking oil. I'm using an SWG also and I'm guessing the small amount of salt caused something to rust. I thought I read that they recommend running fresh water through the pump if used in a salt water pool, but I can't find where I read it. Of course, I never flushed the pump.
    12,000 gal. IG Colorquartz, 1.65hp Sta-Rite with 2-spd motor, 300sf cartridge, disabled SWG, AquaLogic P4, Polaris 280, gas+solar, 6' sheer descent with dedicated pump
