Thread: Replacing the main PCB on Aqua-Rite
    Aug 2007
    Chesapeake, VA
    The original Turbo cell (cell #1) went bad and I replaced it with a new cell (#2).
    The Aqua-rite said I had Hi salt.
    I had the salt tested at 4 locations. 2 used an analog meter, 1 used test strips and the last used a digital meter. All results indicated salt levels between 2800-3400.
    After discussions with Hayward they suggested, cell #2 was mislabeled as a T-5 as opposed to a T-15.
    I replaced cell #2 with cell #3, which was tested good at the pool store and verified to be a T-15. I still had Hi salt.
    Hayward then gave me the phone numbers of several warranty repair places to come look at the cell and box. Their charges are $115-$150 for a service call.
    I feel confident of the salt level in the pool. I feel confident that the cell is good.
    About all that is left is the Main PCB.
    Has anyone replaced a man PCB? It should be similar to replacing computer parts.
    A warranty replacement PCB is $250.
    Ideas and comments are welcome.
    27,000 gal Vinyl Grecian L, Hayward 1 HP pump, Hayward sand filter, Aqua Rite Chlorinator,
    Polaris P955, TF-100, Speed Stir, 400sqft solar panels.
    Jacuzzi J365
    Jul 2007
    Brisbane, Australia
    Re: Replacing the main PCB on Aqua-Rite
    i haven't done it on aquarite, but on most SWGs it's pretty straightforward
    disconnect the cables, undo the screws, remove pcb, put new one, put cables back in
    Mar 2007
    Coastalish 'down easter'
    Not to rub it in, but I suggested the board as being the problem and not the cell . It's very easy to do this, though I've only had do do it a couple of times. Get the new motherboard, take off the inside cover and remove the controls panel (it 'pops' on to 4 white plastic 'stands') the connections are labeled by the color of the wire that goes on to each one. You need a flathead screwdriver, or better yet - a 5/16" nutdriver to replace the board.
    If you have any questions about doing this, ask and I'll help.
    Luv& Luk
