Results 1 to 7 of 7
Thread: Inline filter for vaccuming
    Sep 2009
    Burleson, TX
    21
    My Aquabot Jr just died this past season and since it only lasted a season and a half, I'm kind of loathe to spend more money on another. The one thing I really liked about the Aquabot though was that it sucked up algae great and I seem to get a lot of it in my pool. If I get a regular vacuum head, my only option would be to vacuum to waste which would dump a *lot* of water. If I vacuum to the DE filter, I get a couple swipes with the vacuum before I have to bump it. I'd really like to have an easy to access intermediate filter between the vacuum head and the pump. Does someone make something like that. I wouldn't mind cleaning it so often if its very easy to access (unlike my DE filter which is under decking.
    Or am I just crazy and need to sink more money into another robot?
    Sep 2009
    Burleson, TX
    21
    Re: Inline filter for vaccuming
    This looks promising. Anyone used it?
    http://www.cleanerpools.net/slimebag.php
    Sep 2009
    Burleson, TX
    21
    well, that experiment lasted about 7 days before the seam on one side of the bag blew out.
    30,419
    No type of filter or autovac will completely remove algae from your pool and they should not be thought of in that context.
    Poor water chemistry is what is causing your algae issue and if you want a really sparkling pool, you should address your chemistry issues first and then keeping the pool pristine with almost any vac and filter is quite doable.
    You can vac and filter 24/7/365 and will always have algae until you get adequate chlorine in your pool.
    38,285
    Sorry this thread appears to have been overlooked for a few weeks. I agree with Dave, if you have algae, you have a chemistry problem.
    To clear up the pool you need to follow the SLAM Process and then maintain adequate chlorine that is a function of your stabilizer level, see the FC/CYA Chart. To properly SLAM the pool, you will also need one of the Recommended Test Kits.
    Here is some more reading about clearing up a pool:
    Defeating Algae
    Turning Your Green Swamp Back into a Sparkling Oasis
    Sep 2009
    Burleson, TX
    21
    I'm one of *those* guys that lets the pool go to well....you know what in a hand basket over the winter. I dumped 4 gallons of 8.25% bleach in the pool a couple of days ago and it's killed just about all the algae. It's very thick on the bottom. If I vacuum to waste, I'm pretty sure I won't have any water left. Mainly I was just looking for a good way to vacuum to bring it back from winter hibernation without losing all that water.
    As an update, I've replaced the slimebag with some diesel filter bags from Duda diesel...someone mentioned them in another thread. These work great, but it is pretty labor intensive. The 7"x31" bags fill up with one or two swaths across the pool. The really don't let much of anything back into the pool though.
    I guess it comes down to 1) keep it up over the winter, 2) spend forever vacuuming, rinsing the filter, repeat or 3) vacuum to waste and worry about the water bill next month
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Do you have one of our recommended test kits ? If you do can you post some test results. SLAMMing isn't a one time dumping of bleach in the pool. It's a process of testing and maintaining the SLAM level for your CYA level until the three criteria are met. Have you met all three ?
    Water is crystal clear
    CC of 0.5 or less
    You can pass the OCLT test.
    Jeff
