Thread: Polaris Blower Cuts Out
    walker3733's Avatar
    Oct 2010
    San Antonio, Texas
    40
    I have a Polaris QT blower attached to my hot tub. When I turn it on it will only run for 1 minute and then cut off, then a few minutes later it will turn back on. Any thought as to what I need to replace to prevent this from happening? Thanks in advance for any help.
    Justin
    21,550 Gallon Plaster Pool With Attached Hot Tub, 2.5 HP Pentair Challenger, 60 Sq Ft FNS Plus DE Filter, Aqua Rite SWG T-15 Cell, Aqualink PDA PS8
    Re: Polaris Blower Cuts Out
    I would check that the supply voltage and the voltage the blower is designed/setup to use match. If those match, the next thing to look at is the thermal cutout switch.
