Thread: How to prevent Bubbles in Cat 2000 flow cell
    Masspools's Avatar
    Jan 2013
    Cambridge Massachusetts
    35
    Hi All
    I am working on a commercial pool that uses a CAT 2000 controller along with a flow cell, flow sensor and PH and ORP probes. The flow cell is building up a lot of bubbles, as I can see them coming in, making the sensors useless. The hose that feeds the flow cell is attached directly after the pump at an elbow. I don't know if there is a leak on the suction line causing the pump to produce the bubbles going into the tube. Where else can I place this line along the piping system where the water will flow through it. I tried placing it on the return line but it would not push water through the tube. Any help as to how I can stop the bubbles from going in the tube or replacement of the tube along the lines.
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Re: How to prevent Bubbles in Cat 2000 flow cell
    I am not familiar with commercial, or if your pump is ever off, but can you use (automated) valves to bypass that unit for the couple minutes after the pump turns on? I do that with my solar system.
    Theory being...most air enters and goes through the system when the pump is initially switched on. Once the air is flushed out of the system, activate flow to this device.
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
