Thread: Inteliflo VF Priming question
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    I have an Inteliflo VF that I just did the first Backwash with today.
    The priming everytime you want to do a backwash is driving me crazy.
    Here's how I would normally backwash my DE filter.
    Put valve in backwash position
    Run pump, watch output to see if it is clearing, run a few minutes...
    Put Valve in Rinse, run a minute to bump the DE
    Repeat till I'm happy with the output water being clear.
    This drives you crazy and wastes a ton of water with evertime you start and stop the pump it goes thru an un-necessary priming cycle.
    Any way to go straight to high speed without the prime?
    14x30 PebbleTec(Caribbean Blue) 12,000 Gals BORAX
    Pentair IntelliFlo <<>> Pentair FNS Plus DE
    Pentair 5G Intellibrite w/Intellibrite Controller
    ROME Solarium 125 Heat Pump
    Kreepy Krauly Classic <<>> Pentair 320 Feeder
    Re: Inteliflo VF Priming question
    Setting Priming Features
    1. Press Menu.
    2. Use Down arrow to scroll to “Priming” and press Select.
    3. The factory default is set to priming “Enabled“. To disable, press Select.
    4. Press Enter if you have changed the setting - this will save the selection.
    Also see this page.
    http://www.solarsouthwestflorida.com...le-speed-pump/
    Support the site
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    Quote Originally Posted by JamesW View Post
    1. Press Menu.
    Also see this page.
    Hi,
    The VF doesn't have the enable/disable setting. The video you posted was for a VS. I can't find anyway to disable the priming in the VF.
    They do make things complicated. I think that you could do what you want with "Manual", "Backwash", or "Vacuum" mode. The manual has instructions on how to use these modes. You can also change the priming settings such as speed and duration.
    Support the site
    Aug 2010
    Dallas, TX
    4,052
    Mine doesn't prime during those cycles. What drives me nuts is I can't turn off the requirement for rinse. I don't have a rinse setting on my valve. What I do for that problem is shorten the backwash time and use the rinse for 1 minute as more time on the backwash. Then I move my valve back to normal. But, I don't know why yours primes during those cycles. Strange.
