Thread: Cutting a solar cover
    DONNIE's Avatar
    Mar 2007
    Hey guys! This is my first year with the new pool. We have been heating it up on weekends from 75ish to 84ish and loosing all that heat thru the week. So....I bought a solar cover yesterday. Any tips for cutting to size? I have a small waterfall that falls into about a 2' radius on one corner. Should I cut out for that or let it run on top of the cover? I just want to do it right the first time without screwing it up. There is a pic of it in this thread.
    8500 Gallon Fiberglass IG / Sta-Rite pump,cartridge filter & heater / PoolPilot Dig 220-36 SWG / Testing w/K2006
    Hi Donnie,
    I just cut mine to size a few weeks ago and I just used a pair of sharp scissors. Didn't even have to "cut"...just slid them along the cover and sliced the excess off. I put the cover on the pool and then folded the cover up the wall about an inch or so and cut there. That way I still had material to make adjustments if I happened to cut to short somewhere else.
    Not sure about the waterfall. I would assume you would cut around it so the water goes into the pool.
    Good luck.
