Results 1 to 10 of 10
Thread: So I used PUCKS this winter
    Jul 2013
    East Texas
    51
    When I turned my SWG off....I know I know!!! But I had a weird thing happen. I had some either metal or organic stains on the creases of steps and by using pucks this winter they all disappeared.... Could I be imagining that?? I know you use pucks to test stains, but could they also remove them?
    I was putting the pucks in the baskets also!! I know....
    Also, when should I start adding salt back to my pool? Is there a certain temp?? Time??
    25,000g In Ground Saltwater pool-plaster--rock water fall with water Jets- Polaris 280 vacum-Hayward ecostar pump- Hayward booster pump-TF-100 Test Kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,596
    Re: So I used PUCKS this winter
    I would guess if you had any "stains"----they would have had to be organic in nature if the pucks truly "fixed" it. Maybe they just helped keep up your FC level? I think most folks kick the SWG back in with a water temp of 60. Most won't operate under that temp I believe.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,990
    If it was calcium scale, it could be dissolved by a combination of low pH from the acidic pucks and cooler temperature, which lowers CSI.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Anyone's guess, but I would bet organic stains and extended high FC. And what I would hope it was.
    Essential Links:
    Jul 2013
    East Texas
    51
    So did I make a mistake turning my salt cell off and using pucks this winter?
    Pool water was 61 yesterday.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    That depends on what the pucks did to your CYA level. By that I mean, how much did they raise it. Test your CYA level and see where it's at. For your SWG you want your CYA level to be in the 70-80 ppm range.
    If your water is 61 I think that's warm enough for your SWG to work. 😎
    Jeff
    Richard320's Avatar
    Jan 2010
    18,990
    Quote Originally Posted by Traylork View Post
    That depends entirely on the test results. You might have too high CYA, or too low pH and TA, from using pucks. Testing is the only way to know.
    Also note that you only need to add salt if you lost water due to splashout or overflow or backwashing. Again, the only way to know is to test the salt level.
    Butterfly's Avatar
    South Carolina
    10,045
    As mentioned, SWG's don't produce chlorine when the water gets too cold, commonly below 60 degrees.
    We recommend using liquid chlorine/bleach during the times that the SWG is not working/turned off as liquid chlorine/bleach does not have any harmful side effects.
    You're done SLAMing when:
    Jul 2013
    East Texas
    51
    I guess I will pull the pucks and start adding bleach.
    Is there a formula for the amount of bleach per size of pool?
    Going to wait to turn the salt cell back on and add salt until spring break.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Use this to calc. Amount of bleach to add. http://www.troublefreepool.com/calc.html
    Jeff
