Results 1 to 7 of 7
Thread: Are tanning shelves worth it?
    Nov 2013
    Omaha
    30
    We are still trying to design be best pool for out backyard and keep going back and forth on whether to include a tanning shelf or not. We are most likely going with a vinyl pool so adding a shelf may end up being more trouble than its worth.
    For those that have them, would you do it again? How often are they used? What are some benefits of having them that we may not be considering?
    20k Gallon IG Vinyl Pool - 19 x 34 Rectangle - 3ft to 6ft depths
    Apr 2013
    Central Massachusetts
    174
    Re: Are tanning shelves worth it?
    I thought about it and decided it wasn't worth the $2K they wanted for it. I didn't really like the look when done in a Vinyl pool. What we did invest in was wider, nicer steps. That is our in-pool lounging area as the steps make nice seats.
    I could be missing out though! Let's see what those have to say who do have a tanning shelf.
    26,000 gal 18x36' IG Vinyl Pool - Hayward S244T Sand filter - Hayward Tri-star 2-speed 1.5HP pump - Goldline Aqua Plus SWCG and Controller with Tcell-15 - Aquacomfort 125K BTU Heatpump - Hayward Color Comfort 4.0 LED - Zodiac MX8 suction cleaner - TF100 test kit
    My Build thread
    Readyforapool's Avatar
    Sep 2013
    DFW metroplex
    738
    I'm not much of a swimmer, however, I'm a great sitter! We've vacationed at several resorts both those that have a ledge and those that don't. After our last trip to one without a ledge we both agreed our pool would have to have one. We also included a bench near the middle of the pool and one close to the deep end. Plus I think it will be a great place for grand kids to play (if I ever get any!).
    Finally Done! - 21x34 IG, SWCG, depth - 3.6 - 4.6 - 6.6, Pentair IntelliFlow 3050 vs+svrs, 60 sq ft Pentair DE Filter, 400k BTU Heater, Polaris 280 w/.75 hp booster pump, Pentair EasyTouch wireless, 38 sq ft raised spa, wet edge Barbados quartz finish - ODK w/36 in Napoleon grill
    Jun 2012
    N. Houston
    44
    As I was brushing our tanning shelve yesterday I was asking myself the same thing, is this worth it. I don't think so. I figured my 3 year old daughter would play there but she likes to play in the spa better. I love our robot cleaner, turn it on and let it do its job. Except the tanning shelve is too shallow for the robot and you are stuck cleaning it manually. The way my family uses the pool I don't see a need for the shelf and it creates more work to keep it clean.
    I have talked to people who love them though. Same people who told me I wouldn't be happy without it. A difficult decision.
    16K gal, IG gunite - pebble sheen aqua blue (filled 9/14/2013) , Hayward EcoStar pump, Hayward Tristar Waterfall pump, Hayward cartridge 425, Hayward Goldline Pro Logic PL-PS-8, Stenner Pump, and hayward tigershark qc.
    CCisotope's Avatar
    Aug 2013
    Cypress, TX
    136
    For the tanning ledge, I think it all depends on how you are going to use your pool.
    During our design phase we went back and forth on the tanning ledge. Initially, we thought it would be a nice place for little kids to hang out and play in. But our littlest one has learned how to swim in the deep end quickly so we didn't think the tanning ledge would get much use. So we decided to put a lot of benches and steps in our current design. The top of our first step is quite wide at 18" so a little one can sit in the shallow water along with mom. We have benches along the pool at various depths for kids and adults. The other reason we opted for all the stairs and benches is for our dive in movie nights...we have more seating for kids and adults.
    If you are a sitter and tanner and only like to get your feet wet then maybe the ledge would be the better option. Think about how you are going to use the pool to determine if a ledge will get good use.
    IG Gunite 30k gallons, custom WetEdge finish with glass beads, spa, Pentair 520sq. ft. Cartridge Filter, Pentair 3HP intelliflow V.S pump, Pentair 400K BTU Heater Master Temp, Pentair 2HP Whisperflo- Model WF-28, Silencer Air Blower 1.5 HP, Pentair Boost Rite Universal Booster Pump, Rainbow 320, Easy Touch 8, My pool build:http://www.troublefreepool.com/threa...ypress-TX-Pics
    Nov 2013
    Miami, FL
    348
    We actually just eliminated a tanning deck from our design. Watching our little one play at a friend's pool convinced us it will be fine without one. Instead we opted for a somewhat larger top step. We wanted to just maximize the pool area as much as possible. They don't seem very comfortable to just sit on. I think most people will prefer the spa or a bench... something with a back.
    Swimming!: 19x32 IG rectangular pool, 22,500 gallons; 3' - 6.5'; open spa w/ 6 jets; raised wall w/ 1 sheer descent and 2 minijets, 2 color-changing LED pool lights, 1 spa light; Jandy 2 1/2 HP 2 speed Pump, Jandy cartridge filter (320 SQFT), Diamondbrite Cool Blue
    Apr 2010
    Buckeye, AZ 85326
    619
    Our Baja step is in about 18" of water and is a big semi circle so its the gathering/hangout place for pool parties. We are soakers here in AZ so when its hot out we just stay in the pool during gatherings and parties. We have friends that dont have the baja/tanning shelf and it makes the steps prime real estate and a little harder to convesate and stay gathered. Its also a great area for the kids to play, learn and get use to the water. If you decide to get one have them put a return or two in the area so you can position them to help keep the shelf clean.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
