Thread: Just a Note to Say Thanks
    MrPat's Avatar
    Dec 2013
    Ponce Inlet FL
    12
    I started using this site and especially the PoolMath calculator a few months ago. The test kit TF-100 is great. I have been able to keep my numbers on target without adding tons of chemicals. I turned off my chlorine tab dispenser and got my stabilizer down to acceptable levels. I'm only adding small amounts of liquid chlorine and acid. The water looks and smells great. Thanks!
    6500 Gal. In Ground, Diamond Brite finish.
    Pentair 1hp pump
    Hayward C1200 filter
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Just a Note to Say Thanks
    Congrats on your success !! When you have the right tools for the job things go a lot better !
    Jeff
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by pwrstrk View Post
    ^^^ and
    You're done SLAMing when:
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    X 2 again!
    Welcome to the forum, glad it is helping you!
    Essential Links:
