Thread: Pool Heater After Construction?
    Jul 2012
    Fort Worth, Tx
    40
    Buddy of mine just had a pool built and he's being told not to run the pool heater for 30 days after plaster. Is this true?
    Main Pool: Cl Rectangular Pool/Spa Combo (same height) // Jandy RS8 Controller w/iAquaLink // Jandy VS Flow Pro Pump + Booster // Jandy Heater // Jandy DE Filter // 9,000 Gallons
    Vacation Pool: NaCl Rectangular Pool/Spa Combo (elevated spa) // Jandy RS4 Controller w/iAquaLink // Jandy Stealth Pump (Converted to 2hp 2-Speed) + Booster // Jandy Heater // Jany DE Filter // 9,000 Gallons
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pool Heater After Construction?
    Yes, very true. You can damage the heater by scaling it.
    Essential Links:
    Nov 2013
    Miami, FL
    348
    Our PB recommended leaving out the heater and the SWG of the contract. Since you can't run these things until 30 days after, he recommended adding them later.
    Swimming!: 19x32 IG rectangular pool, 22,500 gallons; 3' - 6.5'; open spa w/ 6 jets; raised wall w/ 1 sheer descent and 2 minijets, 2 color-changing LED pool lights, 1 spa light; Jandy 2 1/2 HP 2 speed Pump, Jandy cartridge filter (320 SQFT), Diamondbrite Cool Blue
