Page 1 of 6 1234 ... LastLast
Results 1 to 20 of 107
Thread: New Pool Cypress, TX Pics
    CCisotope's Avatar
    Aug 2013
    Cypress, TX
    136
    We have finally signed a contract and our construction process begins. Here is the final design of our pool
    Pool specs:
    GUNITE POOL
    22ft. x 36 ft., 674 sq. ft. Angular Pool, 119 ln ft depth of 3 1/2 ft to 6 ft
    3/8 in. rebar on 8 in. 12 x 12 inch box beam containing 4- 1/2 inch rebar
    Gunite: 12 inch continuous bond beam with 6 to 9 inch walls and floors
    6 returns with adjustable eyeball fittings; 4 main drains-2 in floor and 2 in wall
    2 inch suction and 1 inch return lines , 2 skimmers included , 2 separate skimmer lines all the way back to pump controlled by a Jandy valve , 2 main drains in pool w/ VGBA approved Anti-Entrapment Drain Covers, 2 Hydrostatic Relief Pipes in pool main drains
    Fill Line- Automatic (with pressurized vacuum breaker),Overflow- With Drain System
    2 LED multi color Pool light. 3ft sheer descent and two 1 1/2 ft sheer descents on pillars, Wet Edge prism matrix plaster
    ATTACHED GUNITE SPA
    7ftx7ft square
    Raised 18 in. above pool level, 3’ 6” deep
    3/8 in. rebar on 8 in. centers with continuous bond beam of 1/2 in. rebar
    8 Jets, 2 returns and 2 main drains in floor
    Contour seating and multilevel
    COPING: Travertine
    PLASTER:
    Pool: WetEdge Satin and Pearl Matrix custom blend with glass beads and abalone shell
    Spa: Wet Edge custom glass bead blend
    Base color for both pool and spa is Pearl Matrix Mediterranean
    RAISED BEAMS
    (1) 17ft. long X 18 in. high, raised 18 in. covered in glass tile
    (2) 8ft. long X 10 in. high, raised 10 in. covered in travertine
    DECKING
    807 sq. ft spray decking
    DRAINAGE
    4" area drains (out of city) tied into Existing - 5 of these around the decking.
    EQUIPMENT
    Pentair 520 sq. ft. Clean & Clear Plus Cartridge Filter, Model CCP520
    Pentair 3 HP intelliflow V.S Ultra Energy Efficient pump, PN 011018
    Pentair 400,000 BTU Heater Master Temp
    Pentair 2 HP Whisperflo, Model WF-28
    Silencer Air Blower 1.5 HP
    Pentair Boost Rite Universal Booster Pump
    Rainbow 320 inline chlorinator
    Other Equipment:
    Pentair Legend Platinum Pool Cleaner
    2 Pool Light and 1 Spa light- premium LED multicolored with light shows
    2 programable time clocks (pool and pool cleaner),
    Easy Touch 8 Remote system and wireless controller,
    Pool maintenance equipment included: Test kit, pole, brush, net, vacuum hose, vacuum head, thermometer
    All Pentair pool equipment covered by 3 yr. parts and labor warranty.
    Contingency for Sprinkler repair, grass, concrete repair, utilities
    Dig pics are next. I haven't been on the forum for a while but like the changes and the new info on Pool building. It really helps the new pool builder with some basic questions about equipment without having to search through the forums.
    Last edited by CCisotope; 02-28-2014 at 12:58 PM. Reason: Update equipment specs and plaster specs.
    IG Gunite 30k gallons, custom WetEdge finish with glass beads, spa, Pentair 520sq. ft. Cartridge Filter, Pentair 3HP intelliflow V.S pump, Pentair 400K BTU Heater Master Temp, Pentair 2HP Whisperflo- Model WF-28, Silencer Air Blower 1.5 HP, Pentair Boost Rite Universal Booster Pump, Rainbow 320, Easy Touch 8, My pool build:http://www.troublefreepool.com/threa...ypress-TX-Pics
    CCisotope's Avatar
    Aug 2013
    Cypress, TX
    136
    Re: New Pool Cypress, TX Pics
    Here are the dig pics
    Spa area dig out
    Vegas Kid's Avatar
    Dec 2013
    Cypress TX
    187
    Welcome from Cypress.
    I also have a geometric pool similar to yours being built. Keep the pics coming...
    CCisotope's Avatar
    Aug 2013
    Cypress, TX
    136
    They did the steel and some of the plumbing today. They will do the dig for the rest of the plumbing tomorrow and Gunite guys are coming at 11 am tomorrow.
    Here are pics of steel and plumbing. I was really shocked to see that there aren't many tubes for plumbing. I guess if you don't get the in ground cleaner the plumbing guys don't need to stay that long.
    I do have one concern, in the pics you see these cardboard like sheets along the bottom. Is this normal? will this affect the gunite adhering to the ground? and can this cause problems in the future as this cardboard like material starts to degrade in the ground? It did rain a little bit today, so I was wondering if the crew was using this for the mud and just left it behind? I haven't seen this cardboard like material being used in other builds that have been posted so was a bit curious and concerned.
    Plumbing along back raised wall/beam
    spa plumbing and more cardboard like sheets on bottom
    Back side wall/beam
    skimmer with water bottles on bottom
    Bench area
    Drains, two are on the bottom and 2 are on the side. Some PB prefer to do 2 on the side and 2 on bottom, not really sure what the advantage or disadvantage is.
    We have a lot of benches on our build and long stairs with the thought being to have dive in movie nights and to use the back wall to prop up a screen. Also the deep end of the pool nearest the fence will be a dedicated lap lane for the kids to practice their swim strokes, diving and flip turns. Our PB really listen to how we were going to use the pool and ended up digging the deep end on that side to 7ft for safer diving while the rest is 6 feet.
    Hopefully they clean out the water bottles and extra rebarb and piping pieces out before they shoot the gunite tomorrow. More pics to come soon
    CCisotope's Avatar
    Aug 2013
    Cypress, TX
    136
    VegasKid nice design and howdy neighbor.
    It took us a little while to pick a PB and just a couple of things I learned while we were going through this process that might help others. Not only research your PB but also research the contractors and subcontractors they may use. We interviewed a range of PB- from those that are well known and advertise along hwy 290, to the smaller guys. From my experience the bigger guys are not always better, even though they try to justify their high cost with service and quality. Many of these PB use the same contractors so research the contractors too. I personally found the some of the bigger guys to be a little arrogant and always trying to upsell products( like in ground pool cleaner and when you decide you don't want it you never hear back from them). We ended up going with a PB that ultimately came up with this design. We made a few adjustments but he really seemed to listen to what we wanted and how we were going to use the pool. Good luck to those that are just beginning the journey...and take your time to do your research.
    Nov 2013
    Miami, FL
    348
    I like your pool design. Geometrical, but different. I'm also curious what the cardboard material is for along the bottom.
    Swimming!: 19x32 IG rectangular pool, 22,500 gallons; 3' - 6.5'; open spa w/ 6 jets; raised wall w/ 1 sheer descent and 2 minijets, 2 color-changing LED pool lights, 1 spa light; Jandy 2 1/2 HP 2 speed Pump, Jandy cartridge filter (320 SQFT), Diamondbrite Cool Blue
    CCisotope's Avatar
    Aug 2013
    Cypress, TX
    136
    Jro33176: So I looked up the tag on one of the boards and it is Eucaboard made from Eucalyptus trees. The rebar guys used it to keep the rebar out of the mud since it rained a little bit yesterday and it was a little muddy in the bottom. The gunite guy is here today and I asked about the boards, he said it wont cause any problem in the future when it starts to degrade.
    cbink's Avatar
    Feb 2013
    Houston, Tx
    685
    Looking good ! Howdy from another another Cypress neighbor!!
    We also have 2 drains in the floor and 2 in the wall for our waterfall/slide.
    PB said he did it so that waterfall doesn't interfere with main pool drainage.
    We had a similar experience with 'the bigger guys' and also went with a smaller PB (the same as Vegas Kid as it happens). We have no regrets. In fact, my PB was at my house this morning 6 months after finishing the pool to sort out something minor for me. Great service!
    Keep the pics coming! Design looks great!
    38'x24' freeform IG gunite, 26k gallons, 3.5' - 7'
    8t Moss rock waterfall with gunite slide
    SWCG, 2 x 2.7hp Hayward Tristar pumps, booster pump, 425 sqft cartridge, 400,000 BTU heater, Polaris Black Max 280, ProLogic PS8 & Aquapod
    Nov 2013
    Miami, FL
    348
    Interesting about the Eucaboard. Look forward to watching your progress...
    Aug 2011
    Central Valley California
    121
    Nice design. Good luck with the pool build.
    23,000 gal IG Plaster 1989
    Purex Triton FNS Plus DE Filter Model FSNP 60
    1 Hp pump, Polaris 380 w/booster pump
    700 Gal Spa
    Laars Lite Heater T-F 100 Test Kit
    CCisotope's Avatar
    Aug 2013
    Cypress, TX
    136
    Guys came and did the Gunite. It was really cool to watch them do this and the technology that they use in construction is so cool. The gunite guys were great and look at all the nice edges . While I was watching the crew, they were joking with the concrete smoother about his corners and how square they were. So to prove that his corners were nice and square he put the corner of the pegboard onto the corner and it was square. Crew did a great job and were having a good time.
    We are having an additional patio built off of the garage so we will have 2 entrances into the pool one of the new patio and one off the existing. And lots of benches around the perimeter.
    Spa and Steps and Benches pics
    Contour sitting in spa and multilevel:
    Back wall with 3 ft sheer descent and 2 pillars on side with 1 1/2 ft sheer descents in each and bench
    Deep end of the pool:
    Plumbing pics next.
    We just wrote our first big check for this project...it really hurts to see that money go. We live in area with community pools but we have found the upkeep at our community pool to be horrible. After my son got sick(throwing up sick) this past summer from swimming in the community pool we finally decided to go ahead and build. Please tell me it will be worth it in the end... Also what is left of the yard is just piles of dirt and bits of concrete now...but I have been preparing myself. At least our raised garden behind the garage is still intact. The plumbing guys were able to dig next to it and run the pipes.
    We need to figure out our plaster colors next. We will be using WetEdge prism matrix finish in the pool and Jewelscape finish in the spa. Not many people use the prism matrix finish so it is really hard to get an idea of what the color will look like once its filled with water. I've been to the website and wet the sample pieces but one really can't get a good sense of the color. I've found one other post where they use the prism matrix and it looks beautiful. Has anyone else used prism matrix in their pool? For jewelscape, it has been impossible to find pics. Has anyone else used Jewelscape? This will only be in the spa area for us.
    Cbink: I wanted to give you a quick "Hello"! It has been a while my friend. No room in the budget for a kitchen but I took your advice and had them pre-plumb and wire everything for later. Have you started your kitchen yet?
    CCisotope's Avatar
    Aug 2013
    Cypress, TX
    136
    Oh yeah one concern I did have is on one side of the spa there is rebar showing through. I think the rebar guys didn't bend the steel to straight on that one side so when the gunite guys went to smooth it out it was hard to smooth because the rebar curved outward slightly. I am assuming they are going to fill it in later before tile work. Will this cause problems later on? has this happened to anyone during their build?
    Feb 2014
    Houston
    35
    We are using Primera & Satin matrix by Wet Edge for our pool, but the prism matrix is sure gorgeous! I'm sure you'll love it!
    May 2013
    Albany, NY
    59
    Looking good so far, love the step design. No answers for you on the rebar/gunite issue, but from what I've seen on the forums, it shouldnt pose a problem to fill in.
    Jan 2014
    Frisco, TX
    38
    Pool is really looking good. I always like to see it take shape when the gunite is done.
    Dec 2013
    North Texas
    90
    Great looking pool! Did you check them to make sure they pulled the water bottles out of the skimmer before gunite?
    Build is Done!: 18'x40' diving pool, depth 3'6" x 9', 104' perimeter, ~24k gallons, spa (6 jets), raised wall (3 scuppers), tanning ledge, Pentair IntelliFlo 3050 VS+SVRS, Pentair Clean & Clear 520 cartridge filter, Pentair MasterTemp 400 BTU heater, Polaris QT 1.5 HP blower, Pentair Intellichlor IC60 SWG, IntelliBrite 5G lights, Pentair EasyTouch 8 with Screenlogic2, 504 sq ft Roman Slate textured deck, Aqua Blue StoneScapes finish
    Jul 2008
    NJ USA
    146
    Ypur pool so far looks great as a general rule no debries should be left prior to concretin same for gunite . Wow u are sitting on so much clay u didnt need rebar or gunite , all that clay will hold all the water u ant , No just kidding. You want at least 2 inches of concrete over the rebar so make sure the gunite guys or the tile guy fills it for 2 inch over not including the mud for the tile. Also not sure if u are covering ur pool in winter like us up north if u are getting a pool cover like Loc Loop then consider plain Concrete deck around your pool dont use pavers . paver do not allow for good anchoring of the Pool cover. It is worth it if u like pools and splashing around ur money is not wasted dont worry. but U do need to take car of you pool as the Green Monster (AL GEE ) lurks around lol just sayin
    19000 Gal. Fiberglass Inground 44x18 irregular shape pool
    Heat Siphon heater , Cooper Ind. Ranger Series Sand Filter, 3/4 HP Speck pump, Astral inline Chlorinator
    Aquacheck and TF100 tester
    NJ USA
    cbink's Avatar
    Feb 2013
    Houston, Tx
    685
    No kitchen yet. The wife insisted we put down wood floors first before starting any more of 'my' projects! Lol!
    Well hardwood floors are down and kitchen is next on the list. I'm hoping to do it end of this year but we'll see how funds are at the end of the year.
    Gunite looks good.
    And yes, it's definitely worth it!! We too have neighborhood pools but we stopped going when my wife told me the lifeguard had fallen asleep multiple times when she was there. I phoned up the management company and went ballistic. We built a year or so earlier than we had originally intended (hence why the kitchen is phase 2).
    We have pearl matrix not prism I'm afraid. Still, if you want to take a look just IM me - you're more than welcome to stop by and see it.
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Nice design! ..and wow, it appears the Gunite guys did an amazing job overall.
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
  20. Back To Top    #20
    great design.
    who was the gunite sub and what builder did you go with?
