Results 1 to 17 of 17
Thread: Anyone else anxious for 2014 pool openings?
    Feb 2012
    Maryland
    400
    WOW, what what a winter here in MD. I am seeing my safety cover for what feels like the first time since last Nov (exaggeration).
    It was a brutal cold winter, I am hoping everything came out of it ok. My hope is late next month to crack it open and start the assessment.
    Is anyone else getting antsy ready to start the season?
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Anyone else anxious for 2014 pool openings?
    Yes, I have already started watching the temperature start to slowly creep up on the pool, just waiting for the next cold front to knock it back down now though
    Smykowski's Avatar
    Sep 2011
    3,065
    Yes, yes, a thousand times, yes.
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Yes indeed! Current pool temp is 68. In 2 weeks it'll be 89 (for at least 7 days)
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    Dec 2012
    Manassas Park, VA
    207
    Northern VA here and I cannot wait to get started. I already have plans to clean my heater burner assembly and some tile work on the waterfall. This will be my second season with BBB and I cannot wait to get started.
    I will be taking a look under the cover shortly to see how the water looks, hopefully still clear.
    25,000 gallon in ground white plaster- 1 1/2 HP Pentair SuperFlo pump - 60 sqft FNS DE filter (with FiberClear), 1999 Sundance Optima 850 hot tub.
    Manassas Park, VA
    Feb 2012
    Maryland
    400
    Quote Originally Posted by Rocco View Post
    Last I looked was about a month ago, it was clear but frozen solid. No clue how far down it was frozen, but it felt very solid!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Yeah, but I'm a little worried too. We've already had several members reporting freeze damage. I'm hoping it doesn't turn out to be a widespread problem when people start opening.
    Feb 2012
    Maryland
    400
    Quote Originally Posted by JohnT View Post
    definitely my worry too. I suspect the cost of pool parts will be climbing!
    The one time I'm happy I have an AGP. Usually I want to open as early as possible, but most often its not warm enough to put the ladder in for a good month or so. I might as well wait until late April or even May to open this year (whenever it hits 60).
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yea I'm ready too. It'll be a bit. Still lots of snow here.
    Jeff
    Jun 2012
    western NY
    1,560
    I am not sure my pool will thaw in time for a swim season this year. It is pretty much a solid 18' diameter block of ice. I measured the ice temp about a week ago and it is still -7* f. It has to warm up 39* before it even starts to melt.
    Feb 2012
    Maryland
    400
    Quote Originally Posted by danpik View Post
    Silly question, but how did you measure the ice temp?
    Jun 2012
    western NY
    1,560
    Drilled a 1/8" hole to insert a type K thermocouple wire down in about 10 inches. Hooked it to a digital thermometer from work. Should have taken pictures. Next year I might stick the thermocouple in before it freezes and then take readings once in a while. Got the idea from a co-worker who did it on his in-ground pool to measure how cold the water was at the bottom of his deep end one year during winter. He found that even though it had been below 0 for a couple days the water at the bottom of the deep end was still in the balmy 40's
    Feb 2012
    Maryland
    400
    That is brilliant!
    Central Florida
    84
    Been having some warm weather here in Florida, pool temp hit 70 degrees yesterday. 74 and I'm in.
    18k free form IG w/spa (4 jets), Paramount in floor cleaning system, Starite system 3 filter, Jandy 2hp ePump, Sta-Rite SR400LP Maxi-therm propane heater, Jandy aquapure/apurem 1400 SWCG, Jandy automation PS4 w/PDA, IntelliBrite 120v 5-G LED pool & spa lights, 2" piping and (3)4x12 (5)4x10 Fafco Sunsaver Solar Panels.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I'd be in at 70.
    Jeff
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Been warm here for a few days, got home yesterday and the ice had melted. Scooped a few leaves out before dark, still have to get a few more, but I'm ready. Been looking at test kit chems to see what I need refilled.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
