Thread: Valve Question - Is This Setting Correct?
    Jan 2014
    Naples, FL
    36
    I'm sorry, I am still trying to learn valve positions. This is the correct position for the valve correct? Or should it be adjusted? Thanks for your help.
    Size and Type : IGP, 7500 Gallons
    Finish: Wet Edge Satin Matrix Finish (pebble), Cartridge: Unicel Model C-8409, 12 PSi, Pump: 1.5 HP A.O. Smith Model USQ1152 (not sure if it's two speed or variable), Pool Date Remodel: May 2009, Accessories: SWG Auto Pilot Digital Nano Model 75041, Rock Waterfall
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Valve Question - Is This Setting Correct?
    That depends on what you want to do!
    For day-to-day, that's probably correct. If you're intending to drain the pool through the main drain, then the handle should be at 9 o'clock position. If you're vacuuming, you might need it set to 6 o'clock. Essentially, the shape of that handle - where it says "off" - is the same as what's inside. So you can see what it's blocking off.
    EDIT: see posts below
    Jan 2014
    Naples, FL
    36
    Thank you Richard! I couldn't remember if I turned it back the right way after using the vacuum? I remember using the Pool Cleaner and adjusting the RPM's and you're correct, it was more towards 6 o'clock position to increase the RPM's. I just wanted to make sure I turned it back after vacuuming Thanks for the explanation! Much appreciated.
    Don't you want to rotate that around so that the "off" marker is on the side with no ports so that all ports are full open?
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by stebs View Post
    Hmmm, you may be right...
    38,260
    I agree. I would put the handle at 12 o'clock so both pipes are fully open.
