Results 1 to 15 of 15
Thread: PSI and Cleaning Filter Cartridges
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    I have two quick questions....
    We installed our pool in July of this year and our filter is the Jandy 580 sf Cartridge filter.
    After 8 months my PSI is still showing 0 when the pump is running and it bumps to 10 when the Polaris is on, which it has done from day one as well.
    My questions are:
    1. Should I worry that after all this time my PSI is still zero? I do keep the pool very clean, I have no trees over it but the dogs are always dragging dust in dirt into it.
    2. I know I should clean my cartridges when the PSI gets to 25. Do I do it when it reaches 25 when just the pump is running, or do I use the reading when my Polaris is running?
    Thanks!
    43 x 19 Gunite Pool w/ spa and fire pit, 19,000 gallons, Pebble Sheen Aqua Blue finish, Jandy 2 HP VS E-pump, Jandy 580 sq ft Cartridge Filter, Jandy LXI 400k Heater, Jandy Aquapure 1400 SWCG, 4 Jandy LED color lights, Aqualink PDA and Iaqualink, Polaris 280 with Booster Pump. Polaris 9550 Robot Cleaner. 1 HP Silencer Air Blower for Spa http://www.troublefreepool.com/threa...NAL-INSPECTION
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: PSI and Cleaning Filter Cartridges
    Sorry no one has answered you yet.
    Do you think or see that dirt is coming back into the pool? If not, I wouldn't worry yet.
    Use the indication you get during normal running of the system, not by the indication when running the cleaner.
    Essential Links:
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    You've got a huge filter. That is awesome. As long as dirt isn't coming back in you're doing great. Is the pool screened? Trees? Leaves?
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    No dirt at all is coming back, and on a bad day I will get 6 -10 leaves that I fish out. Pb told me, I would probably have to clean the cartridges twice a year. I was just worried because psi has not budged off zero yet.
    Water is still crystal clear, just wanted to throw it out there that everything seemed ok to "yall" At this rate I will only have to clean it every couple of years!
    38,475
    What RPM is the pump running when you see zero psi? You need to check it at a relatively high speed. And then recommend cleaning when the pressure rises 20-25% over the clean pressure ... Not 25psi.
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    My normal RPM's is 1750 that I run from 6-10 hours a day depending on the month. It is at that RPM where it is still zero psi. Thanks for the help so far everyone!
    Apr 2011
    Murrieta, CA
    2,360
    Run your pump at full speed (3600/3500 rpm) and check the pressure.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Sure thing! Let us know how it turns out.
    Essential Links:
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    Quote Originally Posted by bobodaclown View Post
    Full power it jumps to 12 psi
    Quote Originally Posted by Brushpup View Post
    Can't wait to see how your build comes out! I don't know why you said most people don't like the colors you guys picked out, that is why you weren't worried about anyone stealing your stuff....I love everything you guys picked our so far!
    Apr 2011
    Murrieta, CA
    2,360
    Looks like it may be time to clean them. What was the high speed pressure when it the clean filters were installed.
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    It was at 10, the same as when the Polaris is running.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Well, thank you very much Skylar! I vaguely remember saying something like that. About the rocks I think.
    Based on that then, it would be about 20%, so you could give them a wash down and be ready for all summer maybe. What else you got to do on Saturday?
    Essential Links:
    30,431
    Reading this whole thread, I think your system is fine. You have an over sized filter which results in very low psi but that's fine......even better than fine.
    Next you seem to have a pretty darn clean environment around your pool so that big filter has even less work to do.
    I believe I would open up the filter this Spring just for a general inspection and cleaning but it sounds like you won't have to clean very much. Mas985 (longtime member) has a circumstance similar to yours and I think he cleans his filter annually.
    You could always exchange your current filter gauge for a liquid filled one. They have better resolution and would likely show a small psi at your 1750 setting. It's a cheap upgrade.....I reall like mine.
    Apr 2011
    Murrieta, CA
    2,360
    Liquid gauge a nice upgrade.
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    Thanks for everyone's advice! I will look at getting that gauge!
