hi
just fitted the new filter, primed the pump, switched on to pool mode and the pressure has not changed, its still mid 30's with the polaris on
spa not draining but not creating a strong enough overflow from spa to pool when running in pool mode with the return adjusted to spa slightly to create the overflow
any ideas what would be causing the high pressure.
