Thread: Pentair Ultra Temp heat pump 125K BTU alarm
    Austin, TX
    21
    Hi there, turned on our heat pump two days ago because we're going to have a warm week with temps in the 70's. I've been hearing a short low pitch alarm signal about once every two minutes. Nothing shows up on the display as far as any specific alarm message. The fan is running. The pool temp has increased 6 degrees over the last two days from 50 to 56 degrees. We don't have a cover. Also, I have seen no condensation whatsoever being produced. Would anyone have any idea what that alarm might be signifying and what the issue might be? Thanks!
    21K gallon IG Fiberglass pool (installed January 2013), Pentair Intelliflo VS, Pentair Clean & Clear 320, Pentair Intellichlor IC40, Pentair Ultra Temp heat pump 125K BTU, Kreepy Krawly Prowler 830, Pentair Easy Touch 8 with remote, G-Force 2 slide, TF100 test kit.
    Nov 2011
    Moberly,MO
    1,010
    Re: Pentair Ultra Temp heat pump 125K BTU alarm
    Could be any number of things, ambient air temp is very important to the heat pump. If ambient air temps overnight are getting below 60 there is a possibility that the compressor is locking out because it cannot pull heat and transfer it. The alert could be because of that.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
