OK, been doing some pool math today.... This will be handy for anyone interested in installing a home made solar system as the maths will work for any sized pool.... I plan to build 4 (now I've done the math I realise I need one more, I could possibly do 5) collectors Each with 250 metres of black poly tube, if I can get it cheap enough in bulk..... 1 metre of 13mm polypipe has a internal diameter of 11mm..... I do apologise my American cousins, for the metric system, but its all I know...
This only concerns the volume of water held in the tube, not the rate at which it flows, I wont know that till I build it, and then I can customise it, to make it work....
To cut to the chase 1 metre of 13mm poly pipe will hold nearly 100 mls of water, 10 metres will hold 1 litre....100 metres will hold 10 litres....... It makes it very easy to calculate how much water will be in the tubes at any one time.... Therefore 500 metres will hold 50 litres.... Therefore 1 kilometre will hold 100 litres of hot water...... If I can manage it, that's what I'm hoping to accomplish.... With a cycle timer which will turn it on and off every 5 minutes, over the course of a 6 hour period, my solar will have dumped nearly 3600 litres of hot water into my 17200 litre pool.... Not bad considering the hot water is free.....
Now to make this system more efficient, I plant to build everything in neat frames, painted matt black, then covered with a layer of clear plexi-glass plastic..... This will insulate the hoses.....
The pump I am using for the solar, can pump 5672 litres every hour, but its going to be working hard to move water through 1 kilometre of hose, I haven't even bothered to work out how long it takes for the water to make it through the hose and that will be important in determining how many time a day I wish to have it switch on and off and which is more effective in terms of time it takes for the water to heat.... Still heaps of math to do.... I have to add a pipe reducer onto the solar pump to get it down to 13mm from 32mm, that will create some pressure for sure..... :-/
The technical side can be fun...
Just a quick addendum to this post:- Here are the conversions..
13mm = 1/2 inch
1 Litre = 0.267 gallon
1 Metre = 3.25 feet
1 kilometre = 0.62 miles
