Thread: Spa air intake valve
    Aug 2009
    Novato, CA
    22
    The venturi air intake valve for my in-ground spa is this late-1970s Hayward ball valve on a 1.5" PVC pipe. This is the sole air intake for the 3 jets in the spa. I need to replace it because the ball is worn and it won't completely shut off the air.
    The spa air intake valves I've seen at online stores are all for smaller diameter pipes. The 1.5" PVC ball valves I've seen at Home Depot or equivalent are very stiff to operate and seem like they might not even last one season due to cheap construction.
    Does anyone have a suggestion for a valve to use here? A $40 Jandy NeverLube valve seems like overkill, but a cheap plastic ball valve seems prone to failure.
    Thanks.
    -Geoff
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Spa air intake valve
    If you go to an irrigation supply house they will have a better one than the big box store. A Spear or other comparable brand.
    Personally, that's what I would do if I didn't want to spend the extra on a Jandy.
    Essential Links:
