Thread: Please review proposed skimmer/return layout
    wanjayne's Avatar
    Jun 2012
    Wichita, KS
    26
    Would greatly appreciate if the plumbing experts here would take a minute to review my drawing of what makes sense to me at this point. Equipment pad will be south of the house (which is behind steps.)
    Still learning about adding images and not quite there... Here's a link:
    http://s482.photobucket.com/user/Wan...tml?sort=3&o=0
    Big thank you for all comments!
    Jan
    Coming in Spring 2014: Semi DIY 18'x36' rectangular 2' radius ig steel wall vinyl; 3.5'-8'; NO main drain, 2 skimmers, dedicated cleaner line, 5 returns (2 surface, 1 low in deep end, 2 in steps,); 1hp Pentair Whisperflo 2-speed pump; Pentair Clean & Clear 420 cartridge filter; Intellichlor IC40 swg; Raypak Digital NG 399K Heater; (2) Pentair Intellibrite LEDs, 2 wheel Poolvergvegen ; S.R. Smith Salt System diving board
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Please review proposed skimmer/return layout
    I think you are better off having the returns either opposite the skimmers to push debris into the skimmers or the option, in the corners of the pool so that you can get a circulation pattern going that will take the debris across the skimmer. Since your skimmers are near the corners anyway, I would put a return opposite each skimmer and maybe put the step return on the other side of the steps so it faces the skimmer too.
    Mark
    wanjayne's Avatar
    Jun 2012
    Wichita, KS
    26
    Okay.. Made a couple of changes to drawing. Now I'm down to 4 total returns. Is this enough, given we won't have main drains? It seems to me there's a consensus here that if you maximize circulation with skimmers and returns, you can get by without the mains. Is that correct?
    http://s482.photobucket.com/user/Wan...out-1.jpg.html
    Another question regarding skimmer placement... is there an advantage to moving them around the corner so they're on the short walls but still basically in the corner?
    wanjayne's Avatar
    Jun 2012
    Wichita, KS
    26
    Oops... Also, how deep should deep return be and is this a good location for that??
    thanks!
    mas985's Avatar
    Pleasanton, CA
    11,742
    There might be a slight advantage to placing the skimmers & returns on the short wall so that might not be a bad idea.
    4 returns should be more than enough and yes, I would agree that a main drain is unnecessary.
    Deep return is fine. You really don't need much down low when you are only at 8'.
    Mark
    38,521
    The key is having a skimmer on the downwind side of the pool. At least with 2 there is more of a chance of that happening.
