Results 1 to 12 of 12
Thread: Photos from older threads no longer visible
    wanjayne's Avatar
    Jun 2012
    Wichita, KS
    26
    I've saved several build threads into my favorites, for reviewing while we plan for our DIY build which will start in March. Don't know if it's something about my settings or the new forum software, that has resulted in a lot of photos no longer being included in the threads. Was just looking at ssgumby's build and noticed photos are no longer attached. Any ideas??
    Thanks!
    Coming in Spring 2014: Semi DIY 18'x36' rectangular 2' radius ig steel wall vinyl; 3.5'-8'; NO main drain, 2 skimmers, dedicated cleaner line, 5 returns (2 surface, 1 low in deep end, 2 in steps,); 1hp Pentair Whisperflo 2-speed pump; Pentair Clean & Clear 420 cartridge filter; Intellichlor IC40 swg; Raypak Digital NG 399K Heater; (2) Pentair Intellibrite LEDs, 2 wheel Poolvergvegen ; S.R. Smith Salt System diving board
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,083
    Re: Photos from older threads no longer visible
    Can you try to view the thread again and let me know if you see any attachments. If you're not able to see any photo's, please post a link to the thread you are not seeing anything in so that I can see if I'm able to view anything too.
    wanjayne's Avatar
    Jun 2012
    Wichita, KS
    26
    Just opened it up again and Photos were there!!!... Did you make a change of any kind?? I've noticed this with several other old threads in the past couple of weeks. Haven't checked any others, but will let you know if I run into this again.
    Thanks!!
    wanjayne's Avatar
    Jun 2012
    Wichita, KS
    26
    I opened another to find the same issue: http://www.troublefreepool.com/threa...36-Vinyl-Liner
    Jul 2011
    Eastern Ohio
    7,083
    I did make a change to your account, however I'm wondering if it was the solution or not. I opened the link you posted and did see the photos. Go ahead and try to view the thread again while I quickly look to see if any things "off" on your account.
    Remember, you must be logged in to see attached photos. The simplest way to insure you stay logged in is to check the Remember Me check box when you login.
    wanjayne's Avatar
    Jun 2012
    Wichita, KS
    26
    Opened again and still no photos.. This time on one of my other laptops... Logged in at all times.
    Thank you for all your help. This may be something on my end that I'm not savvy enough to figure out.
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    I am struggling with all of my photos on my old threads as well. http://www.troublefreepool.com/threa...NAL-INSPECTION.
    All of my photos were low resolution. Can someone help me and see if I am doing anything wrong?
    Thanks
    43 x 19 Gunite Pool w/ spa and fire pit, 19,000 gallons, Pebble Sheen Aqua Blue finish, Jandy 2 HP VS E-pump, Jandy 580 sq ft Cartridge Filter, Jandy LXI 400k Heater, Jandy Aquapure 1400 SWCG, 4 Jandy LED color lights, Aqualink PDA and Iaqualink, Polaris 280 with Booster Pump. Polaris 9550 Robot Cleaner. 1 HP Silencer Air Blower for Spa http://www.troublefreepool.com/threa...NAL-INSPECTION
    Jul 2011
    Eastern Ohio
    7,083
    I took a quick look, and it show's that all your settings are OK, and should allow for viewing photo's. I've also looked at the thread you linked to, and see several photo's of yours as well.
    Can you try to click on the link again and see if you can view the photo's while logged in?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I can see the pics very clearly. 😎
    Jeff
    30,414
    We have all been doing a pretty good job allowing JasonLion time to sort out these individual bugs. As you know, the transition was quite complex and we will likel be doing this for months.
    remember to give him breathing space and let him and Lee solve one issue at a time before moving to the next.
    It may not seem like it now, but this will give us all a better venue.......just need to shake out the hiccups.
    Thanks, everyone
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    Interesting....it looks like the problem is with my Internet Explorer......Weirdest thing, I can see everyone else pictures but mine using IE. I switched to Chrome and I can see mine as well. Thanks guys for looking. I will reinstall IE. I love the new forum!
