Results 1 to 14 of 14
Thread: New Member - 1st Test Results
    Feb 2014
    Perth Western Australia
    6
    Hello all
    Thanks for this great resource. I am already learning quite a lot already.
    We are located in Perth Western Australia and I thought I would post up my first set of results that have been completed with my newly imported Taylor test kit for the enlightened folks on this website to take a look at and give any advice.
    Being a relatively new pool owner (just over 12 months) I think that these results seem to be okay, but I stand to be corrected.
    Date Hardness Combined Chlorine Free Chlorine pH Total Alkalinity Cyanruic Acid
    15-Feb-2014 200 1 9 7.6 140 70
    Regards
    John
    10K gal, In ground fibreglass, Viron P300 variable speed pump, 150 sqft cartridge filter,
    Onga 25g/hr SWG, Zodiac Power 9 heater,Zodiac barracuda G2 cleaner and Taylor 2006 Test Kit
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: New Member - 1st Test Results
    Welcome to TFP!
    Your Combined Chlorine (CC) of 1 indicates that there is something in the water that the Free Chlorine (FC) is in the process of breaking down. This can happen even if your water looks clear. Therefore, I would recommend that you SLAM the pool as outlined here: http://www.troublefreepool.com/conte...tain-shockingl.
    The rest of your numbers look OK, but I would suggest adding some information about your pool in your signature (in particular the pool surface material, water volume, and whether it is manually chlorinated or SWG)
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I agree with Bo. With a CC of one you need to SLAM the pool.
    Do you have a SWG ? If you don't your CYA is a little out of range for a non SWG pool.
    Jeff
    Feb 2014
    6
    Thanks guys looks like I'm slamming my pool tomorrow.
    No SWG here just an automatic chlorinator.
    Yes my CYA is a little high but the pool gets heaps of sun. I am happy with it being anywhere from 30-70.
    Thanks for your help will let you know how I get along.
    John
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Great ! Sounds like a plan.
    Jeff
    38,275
    Your CYA is now at the top of the range that you think is ok. So that means you can no longer use tablets in your automatic chlorinator and need to switch to liquid chlorine.
    Feb 2014
    6
    Hello
    Just thought I would post my test results from today.
    Hardness 150
    CC 0.5
    FC 12
    PH 7.5
    TA 125
    CYA 50
    Does the hardness really matter in a fibreglass pool?
    Apart from that any recommendations?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I know the CH matters to help protect the gelcoat of a Fiberglas pool.
    Everything else looks ok. Just wanted to ask why your FC is that high ?
    Take a look at this about the CH http://www.troublefreepool.com/threa...berglass-Pools
    Jeff
    Feb 2014
    6
    Quote Originally Posted by pwrstrk View Post
    I think I may have to adjust my automatic liquid chlorinator...
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    By the way how do you like your liquid chlorinator ?
    Jeff
    Feb 2014
    6
    Jeff
    It goes well just have to work out what the optimum dosing level is.
    At the moment it sits on 650 for chlorine which seems to have it sitting a little on the high side
    John
    Feb 2014
    6
    Well I seem to have it under control now latest test reads:
    Hardness 225
    CC 0
    FC 8
    PH 7.4
    TA 125
    CYA 60
    With the chlorine left at the higher level.
    Seems to be okay at the moment, now to keep this beast under control!
    Butterfly's Avatar
    South Carolina
    10,045
    Nice work
    Welcome to the forum
    You're done SLAMing when:
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Numbers look really good. Looks like you have the chlorinator dialed in. 👍😎
    Jeff
