Results 1 to 11 of 11
Thread: Safety covers that are easy to get on/off?
    Jun 2008
    western Wisconsin
    250
    Caveat: I might be looking for something that doesn't exist.
    I need a safety cover for my pool that I can take on/off nearly every day. The primary purpose is to catch any humans who might fall in; the secondary purpose is to catch leaves and bugs before they fall in. I'm relatively strong and good with hand tools. However, it would usually be just one person - me - that would remove/replace the cover. Ideally, I don't want it to take much more than 5 minutes, since I'm watching a little one simultaneously.
    A Loop-Loc-type cover seems like a possibility, but don't they take two people a ton of time to remove/replace? I can't afford one of those motorized track covers, although they sound perfect. Is there something I'm missing?
    Thanks in advance for your ideas!
    26000 gal, in-ground, vinyl pool
    Hayward S200 sand filter, 1 skimmer, 2 returns
    BBB since the first month! :-)
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: Safety covers that are easy to get on/off?
    Not knowing what your setup is you might want to look at pool fences. Some sort of alarm also. My leaf problem is mainly in the spring and fall. I strectch a leaf net across during these times.
    Dave
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    Mar 2008
    Central VA
    328
    OK I can at least answer your Loop Loc question. We have one and love it...I only take it off at beginning of season and replace it at end of season, but it is quite easy. You do have to have it professionally installed (unless you're brave enough to drive anchors into your deck/concrete at the correct measurements), but the anchors screw down into the concrete with an allen wrench they provide (long handle) so that you don't trip over them when you're running around the pool.
    Also, to remove each spring from the anchor, you just slide in a tool they have (looks like part of a vacuum handle) and twist it to release the spring...it really is easy, physically speaking.
    However, you need to fan-fold the cover as it is coming off, and it is probably a little heavy/bulky for one person to manage...you'd be running from side to side, and the cover will sink if it sits on the water too long with no support.
    They do give you an oversized bag to put the cover in (the cover actually fits into the bag) but again, probably a 2-person job.
    hope this helps!
    Todd
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    http://www.poolcalculator.com/
    Dec 2007
    Central New York
    504
    Quote Originally Posted by singerteacher
    I don't think they make such a cover. A fence with lockable gates is the best way to go. If your house is used as one side of the fence; and you have a door from the inside to the pool area, you really have to think about that door.(ways to lock it, alarms, etc)
    Just my opinion.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Jun 2008
    western Wisconsin
    250
    My other half is opposed to fences for aesthetic reasons, but it looks like that might be our only option. Thanks for the advice!
    Dec 2007
    Central New York
    504
    You have an 18 X 36 inground. Don't you have a fence around the pool or yard?
    Hotrod30
    Pentair VF3050 pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Your insurance company will dump you in a heartbeat if they find out you have an unfenced inground pool. You may also be exposing yourself to higher liability than you would without the fence.
    There are some very attractive aluminum fences that run about half what an auto cover costs.
    Mar 2008
    Los Angeles, Ca
    222
    My better have did not want a fence around our pool, because it comes pretty close to the house, so she did not think there was enough room to put a fence.
    So, we ended up with a "semi automatic" safety cover. It has a motor for opening, but you need two people to close/cover the pool. One person needs to be on each side of the pool, pulling the cover over the pool. It is impossible for one person to do this.
    There are these plastic pins that anchor into the ground about every three feet, that need to be pulled out to open, and put in to close. So, it takes maybe 10-15 minutes to open or close the pool.
    And, it is still pretty expensive. Cheaper than a fully automatic cover, but not cheap.
    We would have gone fully automatic, but with the shape of our pool there were walls in the way of where the rails need to be.
    Randy
    25,000 gal fiberglass pool, Raypak 200k BTU H200FDN gas heater, Pentair CCP520 520 sq ft Cart filter, Max-Flo VS2303VSP pump. iWave wireless remote,
    seperate spa, with own pump, cartridge filter, Hayward H200FDN heater
    Jun 2008
    western Wisconsin
    250
    Our backyard is fenced, which includes the pool area, patio, play area, and garden. I would like to let my child play in the backyard freely, but without some safety cover on the pool I have to watch her like a hawk.
    Jun 2008
    western Wisconsin
    250
    Does anyone have experience with the wide mesh safety covers, like Katchakid? I'm wondering how long it takes to remove/replace them. www.katchakid.com It definitely won't keep leaves out of the pool, but maybe I could place a leaf net over the top?
    Dec 2007
    Central New York
    504
    www.katchakid.com .... interesting. I've never seen one in person so I couldn't say if they are good or not.
    Hotrod30
    Pentair VF3050 pump
