Thread: Pumping to waste
    Feb 2014
    Dallas, TX
    77
    Pumping to waste
    So I think I understand this. If I want to vacuum or pump water out of my pool I should set my system to waste and that will bypass the filter completely and pump water out of the waste pipe. This is different from backwash where the water run through the filer in reverse and comes out the waste port. Is this correct?
    My question is how do I set it to do this? There is only one rotary valve on the filter and it just says lock and open. I'm trying to pump water out of the pool.
    Tom,
    22k IG plaster pool, Haywood DE6020 Pro Grid DE filer
    Century Centurion 2 HP single speed with Challenger Pentair front housing replacement. Polaris 280 and Polaris PB4-60 pump. Stenner Injection
    Pool is probably 1980-1990 vintage. Concrete deck
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Re: Pumping to waste
    You are correct on your first statement. What position is that valve normally in just running the pool?
    38,371
    Hold on there ... you only have a push/pull type backwash valve. That does NOT have a waste function like the multi-valves do. I would also NOT recommend using the backwash method to drain a bunch of water out of the pool as you may get debris collecting inside of your DE grids.
    You could add yourself a waste valve. In the horizontal pipe coming out of the pump, install a pool 3-way valve. With one port going to an open pipe. Then you could close off the pipe to the filter and everything would go out the new waste pipe.
    Or you would have to replace your backwash valve with a rotary multi-valve.
    Or you will need to rent/buy a submersible pump.
    Feb 2014
    Dallas, TX
    77
    I thought it was something like that. Nothing is ever easy. Thanks
    Tom,
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    What I have done is remove the grids from the filter, closed the valve to the return and opened the drain to pump water out. Check and see if you have a drain plug on your filter. My Pentair DE filter has a 1 1/2" drain plug on the lower side of the filter casing. The opening is threaded and I added a nipple and discharge hose whenever I need to drain water.
    Love TFP? Become a
    TFP Supporter!
