Thread: Freeze protection and spa
    Feb 2014
    York, SC
    5
    I have a new pool that is set up with freeze protection to kick on at 34 deg. When dp kicks in, it runs the variable speed pump at a slower speed than normal spa operation.
    As you can probably guess, we like to use our spa when it is COLD outside. We end up sitting in the spa and the darn thing kicks into fp mode so the spa jets get cut way down until it cycles. This is quite frustrating but I don't want to turn the to speed pump settings up as they don't need to be that high to protect.
    Any suggestions on how to get around this?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Freeze protection and spa
    Welcome to TFP!
    I can't help you, but I know the people who can are going to need to know what kind of pump and control system you have.
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Good thread! Same issue here; I'll be watching. It would help to let us know which operating system you have.
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    Feb 2014
    York, SC
    5
    Quote Originally Posted by JohnT View Post
    Welcome to TFP!
    Guess that would help!
    It is a Jandy system - Zodiac variable speed pump with PDA.
